Old 03-15-2012, 02:09 PM   #1
licenseless
licenseless's Avatar
brake issues
so this is how it started...
i picked up the truck from the new owner... then drove it to my house... she sat for a few months (i started the motor but never drove her around)
when i got all the paper work done and was able to drive her i drove her down the road and back and the front left rotor was so hot it was glowing red... (didnt even drive a mile) all the other rotors had no sign of this at all...
so i let it cool off (the next day hahahaha) and then i pulled off the caliper and noticed she was siezed... and since its 12 bucks for a rebuilt one i just bought it and put it on.
bled the brakes and drove it around... problem seemed to go away... but i didnt drive very far either...
so the next week i drove her to work... and the front left seemed to have that problem again (after about 12 miles of driving) but it wasnt that bad... so i figured it was just the fact that the truck hadnt been used much...
so then on my drive home... i on a long stretch of road... ( about 8 miles long with out stopping or needing the brakes) i smelled the brakes... and immediatly pulled over... the ****ing rotor was glowing so bright it was insane... it was glowing and i didnt use the brakes to pull over... i used the tranny and the e brake which is for the rear of the car...
i am assuming i have a warped rotor that is rubbing against the brake pad enough to create friction...
so unless anyone else knows what this is that is causing this... please speak up...
i already have 2 new front calipers rotors and brake pads in the mail (for cheap... like 100 bucks for all of it I LOVE JCWHITNEY)
but... if anyone knows what else could be causing this... plese inform me...
phew...
http://fatpunkphotos.tumblr.com/
the dude abides... from your dudely lama
licenseless is offline   Reply With Quote
Old 03-15-2012, 02:42 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: brake issues
you should prolly inspect your rubber lines they may be bad or at least the one on the left which is not allowing a full release of the brake caliper. only other thing could be the proportioning valve or a bent metal line.. but those arent near as likely
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-15-2012, 03:32 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: brake issues
Maybe there is a 1.25 rotor on it instead of a 1 inch and it's to thick for the 1 inch caliper?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-15-2012, 03:51 PM   #4
chevy in my blood
Re: brake issues
Could make sure the caliper pins are smooth also.
chevy in my blood is offline   Reply With Quote
Old 03-15-2012, 03:59 PM   #5
FrankieD
FrankieD's Avatar
Re: brake issues
You didn't say what year the truck is but if the rubber lines look orignal they could be coming apart inside but should change them anyway just for saftey sake my .02
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 03-15-2012, 04:09 PM   #6
joe231
joe231's Avatar
Re: brake issues
x3 on the hose.
They can get internal cracks and blisters that will allow fluid to push through to the caliper but not allow the pressure to release
you can pull the caliper off and try to push the piston back into the bore, if it won't move crack the bleeder screw as you are pushing on the piston. If it moves with the bleeder open you have a bad hose.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-15-2012, 04:58 PM   #7
byeoficr
Re: brake issues
next time it locks like that crack the bleeder. if fluid shoots out under pressure the hose is bad i have had the same problem on a 69 custom.the rotor had grooves in it from the gradual process of deterioration of the insides.
byeoficr is offline   Reply With Quote
Old 03-15-2012, 11:08 PM   #8
jhngardner367
jhngardner367's Avatar
Re: brake issues
Yep,gotta agree on the hose idea.My '85 sat for 6 years,and that's the first thing I had to change! I replaced the rear one,too,just to be safe!
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 03-16-2012, 12:55 AM   #9
Gyawo
Re: brake issues
Make sure you replace the rotors after this is all said and done. All that heating and cooling to the degree that you are saying it has is no good and personally I wouldn't trust them being on my truck. Anytime new pads are installed on a vehicle at the very least the rotors should be turned if possible. I honestly just replace them straight out whenever pads are done. Machining rotors only leads to brake pulsation and it having to be on the hoist again before the pads have worn out.
As stated above too, check yer hoses!
Gyawo is offline   Reply With Quote
