Old 03-12-2012, 11:13 PM   #1
HTX86chevy
HTX86chevy's Avatar
Window switch options HELP
So I have an 86 swb standard cab but I have window motors from a 79. I am having trouble with the driver door master switch. I have been using toggle switches to operate the windows for the past year and have had no problems. I recently had the door panels wrapped in vinyl and wanted to put the original switches back but all I could find we're 6 prong switches. I found a 6 prong harness from the bone yard so I figured simple rewire plug and play right ? Wrong. My original switch had 5 prongs. Window motor on drivers side only has 5 wires. No matter how I try to rig up this 6 prong switch , it just won't work. It smokes, gets hot or both windows will only run very slowly. With the original 5prong switch I had no problems, nor do I have any problems when using toggle switches. I guess my question is: has anyone rigged up anything else decent looking , more modern, or even have an idea how I could go about solving this???? Sorry it took so long to get to the point. I'm fruastrated
HTX86chevy is offline   Reply With Quote
Old 03-13-2012, 06:36 AM   #2
tucsonjwt
Re: Window switch options HELP
I would try OEM online vendors to get the correct switch:
oewarehouse.com
oehq.com
autopartstomorrow.com
gmpartsdirect.com
rockauto.com
Make sure you buy OEM Delco or GM parts for this.
tucsonjwt is online now   Reply With Quote
Old 03-13-2012, 07:19 PM   #3
vegas80step
vegas80step's Avatar
do ya have a picture of the switch... I just spent a few days hating life going threw this.. lol
Joe came through with some clutch info that got me up and running... check out my thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=509736
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy?
vegas80step is offline   Reply With Quote
Old 03-14-2012, 09:57 AM   #4
HTX86chevy
HTX86chevy's Avatar
Posted via Mobile Device I have searched and search for a 5 prong switch
Old 03-14-2012, 10:05 AM   #5
HTX86chevy
HTX86chevy's Avatar
Tucson, thanks for the list of sites. Really helpful , but I could only find 6 prong switches. Vegas, I have actually been using your original post as reference this whole time, but I couldn't seem to get my switches working so I thought I would try my luck at asking again
Posted via Mobile Device I don't have a ground wire btw.
Old 03-14-2012, 10:55 AM   #6
vegas80step
Same switch I used...
You need a ground... maybe you old switch grounded to the door??? but you need to run a ground for that switch...
(looking at the picture)
bottom left it positive, bottom right is ground..
top two left runs to the pass. side door, top two right run to your power window motor in the drivers door..
do you have the single switch for the pass door?
Old 03-14-2012, 05:00 PM   #7
HTX86chevy
HTX86chevy's Avatar
Vegas , you are the $#!+!!!!!! Thanks a lot buddy.
Old 03-15-2012, 08:11 PM   #8
tucsonjwt
Are you looking for 1979 or 1986 switches?
Old 03-15-2012, 09:51 PM   #9
HTX86chevy
HTX86chevy's Avatar
I Am searching for 79 switches
Old 03-15-2012, 10:20 PM   #10
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
How's 'bout these from waton's?
http://www.watsons-streetworks.com/power_windows.html
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-16-2012, 03:56 AM   #11
tucsonjwt
Passenger side one button switch should be GM part number 19251626 or AC Delco part number 11P21. I don't know the number of pins but this should be the one - check it out. This AC Delco part number is available at all of the OEM online vendors noted above.
