Old 03-16-2012, 08:24 PM   #1
MARIOS68PANEL
Active Member
MARIOS68PANEL's Avatar
tac wiring question
I would like to wire in my tac .I didnt see it on the wiring diagrams the are posted. Can some one tell me the ins and outs on wiring the tac.
67 short step
71 Custom
MARIOS68PANEL is offline   Reply With Quote
Old 03-16-2012, 08:28 PM   #2
jjtackleberry
jjtackleberry's Avatar
Re: tac wiring question
DittoPosted via Mobile Device
'71 Chevy LWB all OG
'86 Chevy LWB all OG
It's all a matter of perception
jjtackleberry is offline   Reply With Quote
Old 03-16-2012, 11:59 PM   #3
treveiger
treveiger's Avatar
Same here lol
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 03-17-2012, 10:16 AM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
IIRC it a single wire that runs through a specific hole in the fire wall.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 03-17-2012, 10:44 AM   #5
bmfm64
bmfm64's Avatar
It's a two wire set up. One goes to a switched spot in the fuse panel and the other goes out to the distributor or coil depending on points or hei dist. I also ran a ground wire from the stud on the back to the dash. Try searching more, this is were I found how to wire mine. If nothing else you can buy a repro harness that's plug and plug from any of the big suppliers.
bmfm64 is offline   Reply With Quote
Old 03-17-2012, 12:32 PM   #6
MrSchaeferPants
MrSchaeferPants's Avatar
3 or 4 wire depending on your tachometer.
Probably a White/Red/Black/Green setup, on a lot of aftermarket tachs, the 4th being white, for a lighted tach, if applicable.
Red -Switched 12v from panel/block/wherever.
Black - Ground
Green - Dist-Hei-Coil hook up. (Labled 'Tach' on most Hei's, not sure about a coil)
White- Lights, splice in junction with dash lighting past the dimmer
Not sure if you have a general aftermarket tach, someplace there's settings for 4,6,8 cyl that has to be adjusted.
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
Old 03-17-2012, 01:28 PM   #7
bmfm64
bmfm64's Avatar
Good call, are you trying to wire in a factory tach or aftermarket tach?
Old 03-17-2012, 01:45 PM   #8
Factory or aftermarket/points or HEI?
Old 03-17-2012, 02:13 PM   #9
jjtackleberry
Factory points
Old 03-17-2012, 02:22 PM   #10
MARIOS68PANEL
Active Member
Thanks all. Got it wired and it working fine . Stock tac - HEI dizzy- two wires. one to fuze block ond to dist cap = perfect
67 short step
71 Custom
Old 03-17-2012, 03:14 PM   #11
MrSchaeferPants
Yup, should of been what I asked first.
