Old 03-15-2012, 09:05 PM   #1
nutsfor59
1963 chevrolet 1/2 ton p/u 454 swap
does anyone have any ideas on how to overcome the z-bar/ crosshaft ball on the engine from interfering with the exhaust manifold or headers ???,i'm sure someone has had this problem before and i need to solve it or else give up on the big block idea,i want to use a manual transmission and do not want to get involved with hydraulics,help needed desperately !!!!!
nutsfor59 is offline   Reply With Quote
Old 03-16-2012, 12:36 AM   #2
Captainfab
60-66 Nut
Re: 1963 chevrolet 1/2 ton p/u 454 swap
Without completely re-designing the bellcrank assembly to use the rear stud hole in the block, the easiest is to just convert to a hydraulic clutch. That's what I will be doing if I do end up putting a big block in my '66 C30.
Old 03-16-2012, 03:17 PM   #3
1963c-10
1963c-10's Avatar
I second that....go to hydraulic clutch or have headers fabbed around it. Im told some of the block hugger headers will work. Or factory cast manifolds
1964 Short bed trailer
Old 03-16-2012, 07:51 PM   #4
nutsfor59
hi,i've heard of those things but i could sure use part numbers,brand names or other info,thanks
Old 03-17-2012, 12:43 AM   #5
Captainfab
60-66 Nut
Just what are the 'things' you have heard of?
Old 03-17-2012, 11:22 AM   #6
nwfy
i ued a set of fuul size headers for a 68 chevy 4x4 big block just had to move the one clutch linkage bracket on the shaft from the block to the frame ...my truck is a 63 4x4
nwfy is offline   Reply With Quote
Old 03-17-2012, 11:22 AM   #7
nwfy
oh yes they are headman headers
Old 03-17-2012, 08:55 PM   #8
nutsfor59
i just want to find bolt on parts,not get into fabrication etc,i'll find old headers or different manifolds,surely this stuff was available at one time
