Closed Thread
Old 03-17-2012, 07:08 PM   #4801
dean jendro
Old and crusty
dean jendro's Avatar
Re: What did you do to your truck today?
Started the rebuild of the rebuild. In case you missed it search "disaster".
I decided not to restrip the cab because most of the ugly is just surface flash rust from the fire hoses and burnt material in the shop. I'll just hand sand most of the cab with some scotchbrite pads and use a portable blaster with some gentle media, like walnuts or soda in the cracks and difficult areas.
The entire front suspension and disc brake system will need to come off and either be cleaned or replaced. The very front of the frame will need powder coat touchup, if that's possible. The engine will need some looking into and damaged parts replaced. The transmission should be OK. The Entropy LS radiator will have to be replaced, the new alternator, water pump, new compressor and all the new pulleys on the front of the engine will need replacing.
Luckily my new wiring harness and the LS computer and engine harness were not harmed. The Vintage Air system is probably junk also.
To break up the boring sanding I worked some on my big truck grill. It's all chromed and all I need to do is black out the tie bars between and below the letters and pull off the tape. It should really pop when complete.
All in all, it could have been much worse. Someone could have been severely injured or worse and the truck could have been destroyed. It's just more work and that's OK.
Dean
dean jendro is offline
Old 03-17-2012, 09:56 PM   #4802
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks for posting Dean. I was just about to send a PM asking for an update!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 03-19-2012, 10:12 PM   #4803
E911manager
Picked up the last of 5 trucks that I have bought from around the State. This truck is the best so far. The inner fenders are near perfect, under a layer of rat dropping.. It has the rear steps in the bed that I need too.. So I think I have everything I need to put the front end on... But the love bank is empty again so off on a couple of trips and then maybe I can put it together...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice
http://67-72chevytrucks.com/vboard/s...d.php?t=492640
E911manager is offline
Old 03-19-2012, 10:26 PM   #4804
1enick72
1enick72's Avatar
Set the timing and I got my exhaust finished up, rear trans mount (to keep tail shaft off the e-brake pivot). Started wiring up the fan relay and started fabbing up my ECM mounting bracket. TPI swap is almost complete.
1enick72 is offline
Old 03-20-2012, 01:34 AM   #4805
suzq044
Resident Photoshop Nerd
suzq044's Avatar
got more paint & decided against doing the lower stripe & just go with black, and the 'panel' white.. the painting will come tomorrow!
Digital painting is fun enough though - if u wanna see the original, it's linked in the "PJ" text of my signature. We're missing a 'tooth' (push-bar) up front, so i figured I'd leave out the 2nd one.. lol
If I have any luck tomorrow, it'll look something like this (minus the roof, because I'm short & don't have ladder).. when i'm done O_o
OH, and we found that the front signals are jerry-rigged into place, and the passenger tail-light is siliconed to death, so it's going to be a b*tch to get out, so I can paint behind em.. I suppose I'll have to do alot of taping tomorrow <_<
I haven't asked him if he wants me to paint the wheels tho.. (but that's just me being a girl & wanting stuff to match)
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline
Old 03-20-2012, 09:41 AM   #4806
ABX131
ABX131's Avatar
Last night after work I got the new master cylinder and booster in with my custom made bracket. The lines are hooked up and the distribution block bracket remounted. The custom made linkage for the pedal fits perfect but I cant' get my hand in there to put the nut on the back of the bolt which connect the two..will have to drop the entire ebrake assembly to put it on...
ABX131 is offline
Old 03-22-2012, 02:57 AM   #4807
Touchdown67
Touchdown67's Avatar
Blew out the manual transmission last week driving to work. I was trying so hard to baby it so I could drive it to the transmission shop, now it will have to be towed.
Today my friend Joe came over and put disc brakes and a duel power brake booster on. Brakes are amazing now.
Thanks Joe, you did an incredible job. Too bad my 3 speed transmission couldn't hold up for one more week to try them out. I'm putting a 700r4 in next week. I can't wait to drive her again, it's going to be like a brand new truck
Touchdown67 is offline
Old 03-22-2012, 05:07 PM   #4808
fasteddie1964
fasteddie1964's Avatar
I drove it to work.
Friends don't let friends drive Fords
fasteddie1964 is offline
Old 03-22-2012, 05:07 PM   #4809
forestb
forestb's Avatar
At least we know know how to get the patina look.
forestb is offline
Old 03-22-2012, 05:32 PM   #4810
tobytuttle
tobytuttle's Avatar
WENT TO THE SHOP TO TAKE MEASUREMENTS FOR THE ASTRO TURF BEDLINER FOR THE DUALLY ........ AND WENT BY AS USUAL JUST TO CHECK ON THEM TO MAKE SURE THERE GETTING ALONG
tobytuttle is offline
Old 03-22-2012, 07:33 PM   #4811
Slow Build
Slow Build's Avatar
Nice toybox.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 03-22-2012, 07:34 PM   #4812
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Sent back a ton of push loc fuel system stuff and got all of my new Quick fuel stuff.. WOW shocking to spend 800 bucks on fuel system parts LOL
GMR-PERFORMANCE is offline
Old 03-22-2012, 07:40 PM   #4813
tobytuttle
tobytuttle's Avatar
Originally Posted by slow build View Post
nice toybox.
thank you..... Alot of my time is spent working in the summer , sittin in a company truck and dont have alot of time to use any of it ....maybe in my 40's i will get my self a 9 to 5 and enjoy it
Old 03-23-2012, 09:25 PM   #4814
fasteddie1964
Got my license plate bracket today and put it on. I'm legal now, I have tag light!!!
Old 03-24-2012, 12:10 AM   #4815
chainsaw
chainsaw's Avatar
Taped off everything,cleaned out garage, paint tomorrow.
chainsaw is offline
Old 03-24-2012, 07:31 AM   #4816
tincan1966
tincan1966's Avatar
We haven't gotten much done on our 'Burb. We decided to open up our shop as a full time business, so been putting it all in place. Hopefully will pick back up where I left off a couple weeks ago.
tincan1966 is offline
Old 03-24-2012, 03:36 PM   #4817
64shortbox
64shortbox's Avatar
Smile Re: What did you do to your truck today?
Finally got around to modifying my brake pedal. An idea that I got from doobiebro. I cut the small pedal off my 64's swing arm and welded on a larger pedal from a 73 C10. I got a little a head of myself here, I don't have the disc brakes installed yet but they're on their way. I grabbed a disc brake suspension form an 85 C10, installed all new poly bushings, got 2-1/2" drop spindles from CPP, my Raybestos Professional Grade ball joints arrived yesterday and my 6 lug rotors have been ordered and are on their way.
When I got everything all together the brake pedal looked crooked to me, needless to say I was miffed. With the truck sitting level in the garage I set my angle finder on the brake pedal and its right on the money. It still looks crooked to me tho.
Thanks doobiebro, I sure like your idea. That's what I like about this site there is so much information here and everyone is always willing to help & share what they've learned.
64shortbox is offline
Old 03-24-2012, 04:11 PM   #4818
markeb01
Senior Enthusiast
markeb01's Avatar
Nice lookin upgrade. The reason it may look crooked is because of your eye being distracted by the angle of the gas pedal. I know what you mean though, things that are not plumb, level and square make me nuts. Like pictures on the wall in a doctor's office. They always seem to be at least 5 degrees off level!
markeb01 is offline
Old 03-24-2012, 04:43 PM   #4819
MisterC
MisterC's Avatar
Man I like that upgrade. Looks sweet! I may have to copy that at some point. Great work!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline
Old 03-24-2012, 08:59 PM   #4820
chainsaw
chainsaw's Avatar
Got the whole truck one color, going to do the roof white tomorrow.
chainsaw is offline
Old 03-24-2012, 09:07 PM   #4821
suzq044
suzq044's Avatar
Brought the engine & crank to the machine shop today.. it lowered the Passat (Max isn't road-legal yet) a good 2-4" with the weight. lol
suzq044 is offline
Old 03-24-2012, 09:34 PM   #4822
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
My longest trip yet. I went about 7 miles round trip to the gas station.
Alan's Classic is offline
Old 03-24-2012, 09:50 PM   #4823
LinkbeltOE
Today I installed a rear disk brake conversion on my 66 step side
LinkbeltOE is offline
Old 03-24-2012, 10:39 PM   #4824
64shortbox
64shortbox's Avatar
linkbeltOE,
So how did the disc brake installation go? Fairly easy, or did you have to make a "few" adjustments? Inquiring Minds want to know? I also want to ad rear discs in the future.
Old 03-24-2012, 10:53 PM   #4825
ABX131
ABX131's Avatar
I took my first ride in my 63'. Just got the brakes working and it actually stopped! Had to drive it home from the seller's place two weeks ago with a tow vehicle who provided braking. Tow vehicle no longer needed..
ABX131 is offline
Closed Thread
