03-19-2012, 04:25 AM | #1 |
Turbo 400 shift points
I swapped out the engine on my truck over the past few weeks and have it back together and running. However the shift points are a good 1000-1500 rpm higher than they were with the old engine. What would cause this?
The vacume line and electric kickdown wire are both connected.
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case |
03-19-2012, 05:16 AM | #2 |
Re: Turbo 400 shift points
It might not have enough vacuum so its causing it to hold on longer and with no vacume at all it will shift when the governer tells it too. which will be way too late
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
03-19-2012, 06:37 AM | #3 |
Well im using the same carb/intake/vacuum port as the old engine so it should be getting the same amount of vacuum. I will check the line for breaks and make sure the line itself is not the issue.
03-19-2012, 12:26 PM | #4 |
Just here to tinker
I agree with Cory that you need to check out your vacuum. Does your new motor have a big cam?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
03-19-2012, 10:59 PM | #5 |
It sounds like it might have a mild cam. The engine dropped in was of unknown origin, it sat in a barn for years but was stored with oil in cylinders and turned over freely by hand. We replaced alot of stuff and dropped it in, took my old carb/intake and dropped it onto it, and replaced all seals and gaskets and frost plugs. Engine runs great, just trying to chase down this shifting issue.
