Old 03-18-2012, 11:57 PM   #1
wwporkchop
sm465
I have a 1966 c10 that was 3 on the tree with the saginaw 4 speed i want to put in a sm465 4 speed in it but i noticed my drive shaft has a yoke to slide in 3 speed! Anyone know what i need to do to driveshaft to make sm465 to work its also shorter than my 3 speed transmission! thanks
also if anyone knows parts i need to covert let me know!
wwporkchop is offline   Reply With Quote
Old 03-19-2012, 12:38 AM   #2
1enick72
1enick72's Avatar
Re: sm465
you will need a drive shaft with center bearing
1enick72 is offline   Reply With Quote
Old 03-19-2012, 12:45 AM   #3
wwporkchop
Re: sm465
ok where would i get one at? and where do i mount the center bearing i have a short bed and the drive shaft i have is all 1 piece!
Old 03-19-2012, 12:54 AM   #4
padresag
Re: sm465
you have a few other considerations also. the 465 frt brg retainer is larger than the trans you now have. you either have to have the hole enlarged in your b/housing or put in the later b/housing which doesn't bolt to the c/member. you will thn have to install a rear trans mounting c/member
ron
padresag is offline   Reply With Quote
Old 03-19-2012, 12:56 AM   #5
Captainfab
60-66 Nut
Re: sm465
On a shortbed you don't use a carrier bearing. What you will need is a one piece driveshaft that has a slip joint on the trans end. Then the U-joint will bolt up to the yoke on the back of the SM465. In your case you will have to either find a used one in a wrecking yard, or private party, or have a new one made. If you can find one that is too long and have it shortened, that will be less money.
Old 03-19-2012, 12:59 AM   #6
Captainfab
60-66 Nut
Re: sm465
Glad you mentioned that Ron. Yes he will have to change the bellhousing. However all he needs is a '68-'72 bellhousing. They came with the SM465 and still mounted to a crossmember. I happen to have 2 or 3 laying around.
ron
Old 03-19-2012, 01:04 AM   #7
wwporkchop
Re: sm465
Awesome thanks for the info would u want to sell a bell housing also on the drive shaft what year truck would i need one out of also i can make a crossover if needed! thnaks
Old 03-19-2012, 01:29 AM   #8
Captainfab
60-66 Nut
Re: sm465
Yes I would sell a bellhousing. I would like $40.00 plus shipping. Send me a PM if you are interested.
For a driveshaft, one from a '63-'87 shortbed truck with a 4 speed should either bolt up or be workable.
Old 03-19-2012, 11:07 PM   #9
wwporkchop
Re: sm465
well i checked my bell housing and it does fit the muncie sm465 so i wont need a bell housing i will find a drive shaft at the junk yard tks for your help everyone!
