Old 03-20-2012, 09:57 AM   #3551
TXPinstriper
TXPinstriper's Avatar
Re: 67 cheby's Dropmember build thread
Looks great !!!
TXPinstriper is offline   Reply With Quote
Old 03-20-2012, 10:07 AM   #3552
67cheby
67cheby
67cheby's Avatar
thanks guys , i think it will look much better and use a lot less filler !! LOL
67cheby is offline   Reply With Quote
Old 03-20-2012, 11:02 AM   #3553
tubbedII
needs more $$$
tubbedII's Avatar
That looks great!!! You picked up that bead roller technique really fast!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 03-20-2012, 11:05 AM   #3554
67cheby
67cheby
67cheby's Avatar
My friend teaching me has a really nice automatic drive bead roller !! I want it , but for now I will just borrow his !
Old 03-20-2012, 11:05 AM   #3555
raull
raull's Avatar
sorry mike have to ask , the sick part of my mind its cracking up
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 03-20-2012, 11:07 AM   #3556
67cheby
67cheby
67cheby's Avatar
Needs viagra, lol, a rubber boot grommet for my EFI wiring out of driver door of 2009 Malibu
Old 03-20-2012, 12:20 PM   #3557
watahyahknow
watahyahknow's Avatar
i've seen a couple of beadrollers they motorized themselves , the eaziest way i can think about in therms of a one stop partsource is using a 24 volt electric motor and motronic out of an immobilitycart
(i know this one is chaindriven and has forward and reverse on one handle)
or a big kids toycar driving a cycle-chain and sprockets
you could use the handle of the cart and beef it up to a two way footpedal and have forwarth and reverse (depending on wat cart you happen to find )or buy am old pedal from a tig welder or a volume pedal for a guitar to regulate the motronic (you only need a liniar potmeter for control of a motronic on a inmobillitycart ), doing it that way you can drive it at any speed the electric motor is powerfull enough to move a person up the hill at a little over walking speed and can be driven of two batteries if needed
i wouldnt be suprized if a windowmotor out of a car would be strong enough too if a lot slower but you wouldnt have the speedcontroll
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-20-2012, 12:51 PM   #3558
xpickup
xpickup's Avatar
I used a winch from Harbor Freight and sprockets and chain from McMaster-Carr. I bought the 110v winch so there no need for a battery, just plug into the wall. I work in a machine shop so I remade the cable drum for the sprocket. It works great. I now can do my panels by myself and do not have to worry of having someone cranking to fast or far or even getting someone to crank it at all.
Shannon
xpickup is offline   Reply With Quote
Old 03-20-2012, 02:31 PM   #3559
67cheby
67cheby
67cheby's Avatar
great ideas !
Old 03-20-2012, 02:39 PM   #3560
watahyahknow
the winch or any electric motor would work but you cant controll the speed its either on or off it would help to be able to slow down in tight corners and when you need to follow another bead
i wonder if an old chevy cam drive/chaindrive is big enough for the job then you can even use the camdrive cover
Old 03-20-2012, 03:04 PM   #3561
David67
David67's Avatar
that looks awesome!!
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 03-20-2012, 03:23 PM   #3562
67cheby
67cheby
67cheby's Avatar
thanks David
Old 03-20-2012, 06:48 PM   #3563
67cheby
67cheby
67cheby's Avatar
wanted to share a little of today's excitement with you !! SLOSH TUBZ SQUARED !! COMING ALIVE !
Old 03-20-2012, 07:01 PM   #3564
oldman3
oldman3's Avatar
Those look good, nice job....Jim
oldman3 is offline   Reply With Quote
Old 03-20-2012, 07:40 PM   #3565
Tinkermc
gotta love the progress you have made
Tinkermc is offline   Reply With Quote
Old 03-20-2012, 08:17 PM   #3566
raull
raull's Avatar
some guys are gona lov ya !!!!!!!
raul
Old 03-20-2012, 08:24 PM   #3567
longbed67
longbed67's Avatar
That flush trim with the bead roll looks tight!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 03-20-2012, 10:50 PM   #3568
mcbassin
Still Learning
mcbassin's Avatar
I'm loving the firewall filler plate. I did the full replacement on mine and got a nice bow in it from the welding. I tried to shrink it out. Got it better but it is still not close to flat. you shouldn't have to much warpage on yours with the bead rolled. Are you using Vintage air kit ? I cut my pass through for the heater hoses and a/c lines. I'm not real happy with how it came out. I'm just curious how you are going to route your lines?
The new tubs look Killer!
Old 03-20-2012, 10:58 PM   #3569
VA72C10
VA72C10
VA72C10's Avatar
Nice work on that firewall! And the STx2 look good
Old 03-21-2012, 05:27 AM   #3570
LakeAnna
LakeAnna's Avatar
Are those for me!!?? LOL
Looking good.
Chris
72 RESTO
http://67-72chevytrucks.com/vboard/s...d.php?t=501870
LakeAnna is offline   Reply With Quote
Old 03-21-2012, 05:44 AM   #3571
67cheby
67cheby
67cheby's Avatar
Thanks guys I am extremely excited about all of my current progress, it seems like for a change everything is actually going right !! Yes I am running vintage air and my hoses will come out far on the passenger side so I can hide them over the inner fender
Old 03-21-2012, 05:45 AM   #3572
67cheby
67cheby
67cheby's Avatar
Looking good.
For anyone who wants to buy a set , if you want to pay now the first set can be yours !!
Old 03-21-2012, 06:11 AM   #3573
longbed67
longbed67's Avatar
Does vintage air provide enough hose to do this??? I am very curious to see how this will work!
Adam
(608) 214-8706
Old 03-21-2012, 08:11 AM   #3574
67cheby
67cheby
67cheby's Avatar
No I will have custom hoses made, look up ES67 build thread he ran his this way SUPER CLEAN !!
Old 03-21-2012, 08:25 AM   #3575
FrankieD
FrankieD's Avatar
Looks nice. Will you have to trim the inner panel for suspension clearance?
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
