11-03-2009, 01:56 PM | #26 | |
Just a nother gear head
Re: 2000 6.0L runs rough and stumbles
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
11-03-2009, 03:30 PM | #27 |
bad fuel pressure regulator I've seen it many time on these
11-05-2009, 07:09 AM | #28 |
Nope, changed that too when it had a hard starting issue.
11-05-2009, 01:28 PM | #29 |
Factory Strippers Rule!
Where is is the regulator on these things? Maybe I should change mine. BTW, when my truck broke a valvespring, the check engine light never came on when I thought for sure it should...
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
11-05-2009, 01:55 PM | #30 |
If you have a feed and return line on the fuel rail then the little round thing that has a vac line attached to it is the regulator, if you only have 1 line to the rails then it is in the tank, part of the fuel pump assembly.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
11-07-2009, 07:06 AM | #31 |
that is correct. it is on the drivers side fuel rail. check and see if it is good is by running the truck or cycle the fuel pump with the key, shut it off then up plug the vac line from it. If gas comes out of the port then it is no good. A nother sure way to tell is if your truck starts hard ie cranks over for a little bit before firing up. the pressure reg is a dealer only item and is just over a $100 bucks.
a broken valve sring wouldnt trip the check light.
11-08-2009, 12:03 PM | #32 |
i did not think of the valve spring but they are common on these style motors
02-20-2012, 08:03 PM | #33 |
I've got the same issues with hesitation and stumbling on my 2000 6.0. The fuel pump took a dive so I've already replaced that. I've put in a throttle position sensor, crank sensor,mass air sensor, and still falls on its face when you try to accelerate. I took it to a shop and had it plugged into a scanner that uses live feeds. It told me that 4 out of the 8 coils were missing under a load. I just ordered a set of 8. This truck has literally broke me lol
Posted via Mobile Device Posted via Mobile Device |
02-20-2012, 08:08 PM | #34 |
I forgot to mention that I also did a fuel filter and regulator when I did the pump. Also, keep a good eye on the fuel filler neck. Apparently they're known for rotting out and the rust falls down in the tank along with the outside elements. It was a mess!
03-04-2012, 02:47 AM | #35 |
Don't pay someone for a live fuel pressure feed. I was a mechanic and all we do is take off the engine cover and connect our mechanical fuel pressure gauge to the shrader valve and drive the thing. save your money.
I'd check pressure first then grab a bottle of brake parts cleaner and a roll of shop rags. Clean the throttle body, pull the egr valve and clean it out. then reach as far as possible into the intake if you don't have cash for injectors pull them out, remove all rubber and soak them in acetone over night You'll be amazed what it'll remove. Oh and when I said a can of brake parts cleaner I mean a case. A lot of problems with new gm motors are traced back to carbon build up and intake gaskets. But I'm new here so don't take my advice as Gospel. |
03-05-2012, 07:46 PM | #36 |
I'd put money that it's not coils, and if you just bought 8 of em you wasted your money. I have never seen one go bad, not that they can't, but extremely unlikely that 4 went at one time. If you did have 4 dead coils you should be looking at power supply issues before replacing coils. Personally if they told you that it needed coils from just data streams and not actually testing anything, i'd say they are just tryin to suck ya for money and don't really have any idea what they are talkin about. What are the fuel trim readings at? O2 sensors responding properly? Have cats been checked to see if they are coming apart and plugging exhaust? Maf sensor readings and map/baro reading would be helpful as well. Would also check iac as well.
03-05-2012, 07:52 PM | #37 |
Come to find out.....I had a couple cooked plugs and a bad spark plug wire. I changed the plugs and got the one wire replaced and this truck runs better than it ever has! The wire was broken internally and it was arcing to the head. This thing is a beast!
03-13-2012, 02:59 AM | #38 | |
03-13-2012, 05:32 AM | #39 |
I would seriously consider looking into the fuel filler neck and the fuel pump. The filler neck was completely rusted out so the rust, water, mud and every other outside element went down inside the gas tank. It was messy and a pain to fix and clean, but what a huge difference! My gas mileage even improved
03-13-2012, 12:37 PM | #40 |
good suggestions to look at but not an issue on mine. i changed the pump and filter a few yrs back and just had the bed off to do some body rust repair, filler neck is fine. im thinking a nother bad coil pack. have to bring it back to dealer to be scaned.
03-13-2012, 09:06 PM | #41 | |
03-13-2012, 09:45 PM | #42 | |
03-22-2012, 10:19 AM | #43 | |
