73-87 will a 4" lift with 35's rub
I have a 4" lift and just got a pair of 35/12.5/15 inch tires for my '86 half ton 4x4. Was wondering if they would rub when steering or if they might hit fenders without cutting, thanks!
Re: 73-87 will a 4" lift with 35's rub
They'll more than likely rub. 4" and 33" is a perfect combo..... for 35" I'd go with 6".
RIZ |
They won't rub unless you're flexing and hitting a bump. You'll be fine. Lots of people do it and I think it looks great. 6" looks like too much lift for 35's, IMO. I only had to take a half inch of each bottom corner of my wheel well in the front to clear 38x15.50's on a 6" lift.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
It followed me home?
x2
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
using an 8" wide wheel as opposed to a 10" wide wheel will help keep the rubbing to a minimum.
I agree with using an 8" wide wheel, as well. It looks better to me anyway, too.
This is the same set up I had and it would only rub occasionally, but nothing serious. And, that was with a plow on the front. However, I'm going with 16" this time around and cutting the front fenders (to avoid rubbing at all and just because I think the fenders look better cut).
79-87 3/4T Plow Truck. Running Gear all 79, body is 84-87. Originally built by my Dad & Brother in late 90's early 00's. I bought the truck in summer of 11; dad & brother put new box sides on, and surprised me with a new paint job. Jan of 12 the float stuck in the carb and she burned... The truck is back in MI now and being re-built AGAIN by my Dad & Brother. http://67-72chevytrucks.com/gallery/...8633&protype=1 |
i have a 10'' wheel with a 4'' lift and 35's on my 77 cc and they rub over the slightest bump at full lock.i will be going to a 6'' lift soon!
I have 7" on my '86 with 35s on 10" wide rims & the front fenders are cut out cause they rubbed. 33 s work real good on 4" lift even with 10" wide rims. IMO the wider 10" rims look way better,especially on a 16 or 15" tire,lots of sidewall that way too.
Posted via Mobile Device Posted via Mobile Device
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
Mine only do at full lock when turning left. It will be getting a body lift soon.
I am running 15x10 rims and 35x13.5 tires.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
ive got 35's on 7 inch factory suburban wheels and only a 3inch body lift and wore stock springs and they will hit if you try but not daily driving, ive seen plenty of trucks with 35's 4in lift and 10's but there cutting it close but a little bit of a trim were the fender rolls under and your good unless your playing baja driver
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s ![]() |
i've got a rough country 6" lift with 35's on 15x8 wheels. no rubbing and i think it looks awesome. the only thing want to do differently is get some 10" wide wheels.
the rough country springs arent much rougher than the factory springs IMO. |
