Old 03-22-2012, 07:24 AM   #1
jessewebb
jessewebb's Avatar
Question about tires and wheels
I'm getting ready to buy these wheels for my 69 C\10. I have a couple questions I was needing some help with. I need to know the correct a size for these wheels? I have a 5-3 drop and I'm going with 2.5 drop spindles. also is these going to fit alright with my inner fenders? the size of the wheels are: 2) 20x8.5 2)20x10 RIDLER CHEVY TRUCK 5 on 5. Patteren $825 shipped to my door, with lugs???? Any help would be appreciated. Tire size, inner fender clearance, Price?? Anyone used these
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 03-22-2012, 07:59 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Question about tires and wheels
What backspacings do they come in?
Also,... what year rearend is in your truck?
Keith
Convert to disc brakes.
Old 03-22-2012, 07:59 AM   #3
lolife99
lolife99's Avatar
255/40 and 295/40 would be my choice for tires.
Keith
Old 03-22-2012, 08:25 AM   #4
jessewebb
jessewebb's Avatar
Lolife99. My rear end is a 72. I think the back space on the rear is 5 or 5.25 the front is 4.75 or 5. I'm waiting on replies on the drop spindles. Not sure what year the front is yet. 255/40 on the front and 295/40 on the back ?? I'll look up the item # for the wheels there on Ebay. If you have the time, I'd appreciate it if you'd take a look and give me the exact fitment I need. Rsally don't want to make a mistake on these. Thanks Pete
Pete
04 325i lady's ride
Old 03-22-2012, 08:33 AM   #5
jessewebb
jessewebb's Avatar
Item # 230726624458. I think that's a decent price shipped. I've looked around. Haven't seen anything in that style for the price. If you will tell me what I need back spacing. I will call them and see if they can hook me up. Thanks again
Pete
04 325i lady's ride
Old 03-22-2012, 08:57 AM   #6
CC69Rat
CC69Rat's Avatar
sup Pete ! Haven't talked to you in a while..
Good choice on the wheels.. and you've got THE MAN helping you out on this .. He's all over it on the wheel / tire combo. I personally went 255/45 and 295/45 for my uncoming GMC slam'ola. (just personal taste, I like a little more sidewall and more 'stuffed' look) .. but I'm only doing 4.5-5" up front and 6" in the rear.
If you're doing 5.5" drop with 3" springs and 2.5" spindles up front, I would suggest 20x8.5 with 5.25 Backspacing (or even 5.5" depending on how you want it to look) 255/40.
5" drop in the rear, 295/40 on a 5.5" Backspacing - 72 rear end. It will measure 57" from backing plate to backing plate if you want to be sure . -- Afterall, I too learned from THE MAN lolife99
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-22-2012, 09:23 AM   #7
jessewebb
jessewebb's Avatar
I have to agree with you. He knows his stuff for sure. He's helped me out on more than one occasion. Thanks for the info. Good to hear from ya
Pete
04 325i lady's ride
Old 03-22-2012, 12:38 PM   #8
jessewebb
jessewebb's Avatar
Have any pics of yours on the truck. Get an idea of how the higher sidewalls look?
Pete
04 325i lady's ride
Old 03-22-2012, 12:58 PM   #9
tobytuttle
tobytuttle's Avatar
dont remember the backspace on my truck ,be that it was done sooo long ago..... imo i would revert to the stock ralley wheel offset and cheat a little to the inside for width/backspace....there's 22'' on my truck at the moment... and i have had all kinds of wheels on this.... 15 inch boyds then 17 inch welds then i thru these 22's on for the look....but im going back to the 15'' either weld draglites or corvette rallys once i put all the factory molding back on...
tobytuttle is offline   Reply With Quote
Old 03-22-2012, 01:08 PM   #10
CC69Rat
CC69Rat's Avatar
Pete -- I just received my tires yesterday. Don't have my wheels just yet.
From what I can tell a 255/40 vs. 295/40 = 1.3" overall. (front tire vs. rear tire height)
255/40 = 28" tall. 295/40 = 29.3" tall.
The same combo in 45 series 255/45 = 29" 295/45 = 30.4"
So .. basically an extra .5" of sidewall top and bottom by going with the 45's. My truck will be driven a lot (this one.. not really a show truck) so I thought maybe the 45's would be better for potholes etc. I like to build the drop around the wheels and tires.. not 'fit' the wheels and tires to the drop if that makes sense?
Tires and wheels - bolted on the truck (or at least underneath it, with correct Backspace) Measure it as is, then measure where you want it .. and by the drop to make it happen. That's just the way I have done it in the past (when possible)
I'm going 4.5 / 6" drop (not really hauling anything to speak of) .. maybe 5" drop in the front (GMCPauls I believe it was has a 2.5" drop front spring + 2.5 spindles) Or snip 1/2 turn out if needed.. yadda yadda.
anyway, here are mine.
Chad
Old 03-22-2012, 05:43 PM   #11
lolife99
lolife99's Avatar
Per the ebay ad:
20x8.5" ARE 4.75" BACKSPACING OR ZERO OFFSET
20x10 ARE 5.5" BACKSPACING OR ZERO
The backspacing will work up front,...but I like a a 5.25"-5.50" backspace on 20x8.5 wheels, so they tuck.
The 4.75" BS will limitthe amount of drop you can do up front,... because the wheels will be close to the fender lip.
The rear 20x10's will work fine with a 5.5" BS and a 71-72 style rearend with your fleetside bed.
Keith
Old 03-22-2012, 05:53 PM   #12
lolife99
lolife99's Avatar
CC69Rat I applaud you for taking the time to buy the correct wheels, with the correct backspacing and tire size,... and to make the end results look GREAT,... not just "OK",... because "I got a great deal on the wheel/tire combo",... like so many do.
I do approach the measuring exactly opposite of the way you do.
I always set the ride height first. (static or bagged)
Then I measure for wheels.
It is so hard to calculate what "drop" the suspension companies products are going to give you,... until you install them.
Once I'm happy with the drop,... I buy wheels.
That's the only way I know to measure the size, and backspacing accurately.
That's just the way I do it.
As long as the end results are great,... I guess it doesn't really matter.
Like I always say,... measure, measure, measure!
Keith
Old 03-22-2012, 09:01 PM   #13
jessewebb
jessewebb's Avatar
how about these lolife99 Think this might be the size you would reccommend
5 ON 5 CHEVY GMC TRUCK BOLT PATTERN
2) 20X8.5 = 5.25 BS
2) 20X10= 5.5 BS
Pete
04 325i lady's ride
Old 03-22-2012, 09:10 PM   #14
lolife99
lolife99's Avatar
Those numbers will be fine.
Keith
Old 03-23-2012, 07:44 AM   #15
jessewebb
jessewebb's Avatar
Why do you run the 295's in the back? Why not 245's all the way around?
Pete
04 325i lady's ride
Old 03-23-2012, 07:49 AM   #16
lolife99
lolife99's Avatar
A 10" wide rim requires a wider tire.
(295 represents the width of the tire)
Look at Nate's truck.
It has 255/40's and 295/40's with 20x8.5's and 20x10's.
Keith
Old 03-23-2012, 08:43 AM   #17
jessewebb
jessewebb's Avatar
Gotcha, Makes sense to me know. I feel I got the exact answers I was looking for. Sheew, now just parting with the funds. Thats the hard part. Thanks Guy's I really appreciate.....BTW: That is one sharp truck
Pete
04 325i lady's ride
Old 03-23-2012, 08:47 AM   #18
CC69Rat
CC69Rat's Avatar
Pete -- you know for sure you have the late rear end housing? Your truck being a 69, it sould have the early rear end in it. which would change the offset of your wheels slightly.
Ex. The early rear end is 55.5" plate to plate so you need 20x10 with 5" BS on the rear
the later rear end housing is 57" plate to plate so you would want 5.5" BS on the rear to offset it.
Chad
Old 03-23-2012, 09:50 AM   #19
jessewebb
jessewebb's Avatar
That's about the onlly thing I do know about it. The year end housing has 1972 on it, in that yellow marker paint junkyards write on there parts with. Lol. I hope it is. I've already bought the wheels and goin with your idea's on the tires due to the terrain here.
Pete
04 325i lady's ride
Old 03-23-2012, 11:13 AM   #20
CC69Rat
CC69Rat's Avatar
That will completely change the look of your truck. Post up some pics when you get them on
Chad
Old 03-23-2012, 12:13 PM   #21
jessewebb
jessewebb's Avatar
I hope. Gotta lot of work ahead of me yet. New cab, doors, a bunch of different stuff to do yt. Thanks for all the help Pete
Pete
04 325i lady's ride
