Old 03-24-2012, 12:04 PM   #1
notsolo
notsolo's Avatar
Blazer Bodyguards
As with most Blazers they were run hard and put away wet...the front wheel wells were designed pretty good and front fenders were protected.. NOT SO MUCH BEHIND THE DOORS. the front side of the rear wheel wells is a open pit that collects everything...P-O did a coverup by replacing the outer rocker panel. I never heard of or knew about rocker boxes (Torsion Boxes) 15 years ago when I bought this truck. After a lot of scraping- cleaning- priming- and replacing undercoat I repaired what I have, the best I can do without welding....Sorry to say I don't have the funds to strip out each side to make it right. Its going to be a street ride no longer 4x4 the conversion is almost complete. Mostly what I have is solid so it is mostly there. To preserve what is there I made a shield out of 1/8 diamond plate to reduce amount of crap and water from getting into this area... Pattern made out of cardboard, then bigger... cut and fit few dozen times... repeat with aluminum diamond plate.
notsolo is offline   Reply With Quote
Old 03-24-2012, 12:11 PM   #2
notsolo
notsolo's Avatar
Re: Blazer Bodyguards
Originally Posted by notsolo View Post
As with most Blazers they were run hard and put away wet...the front wheel wheels were designed pretty good and front fenders were protected.. NOT SO MUCH BEHIND THE DOORS. the front side of the rear wheel wells is a open pit that collects everything...P-O did a coverup by replacing the outer rocker panel. I never heard of or knew about rocker boxes (Torsion Boxes) 15 years ago when I bought this truck. After a lot of scraping- cleaning- priming- and replacing undercoat I repaired what I have, the best I can do without welding....Sorry to say I don't have the funds to strip out each side to make it right. Its going to be a street ride no longer 4x4 the conversion is almost complete. Mostly what I have is solid so it is mostly there. To preserve what is there I made a shield out of 3/16 diamond plate to reduce amount of crap and water from getting into this area... Pattern made out of cardboard, then bigger... cut and fit few dozen times... repeat with aluminum diamond plate.
A 2"x 4" angle was cut and added to the end of the Rocker box to hold the Diamond Plate on. also added door weather strip to seal sides and top, Not perfect but should reduce crap build up by 90%
Old 03-24-2012, 01:18 PM   #3
71HUGGER396
Confirmed Truckaholic
71HUGGER396's Avatar
That's a great idea.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b
Daily Driver, 1970 Cst short fleet, all black, 350/350,
1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road
1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72
"My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road
SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin"
71HUGGER396 is offline   Reply With Quote
Old 03-24-2012, 02:00 PM   #4
BOHICA
BOHICA's Avatar
How do you like your poly body mounts?
1954 Ford F-100
1956 Chevy big window
1970 4x4 Blazer CST
1987 Land Cruiser
1990 Chevy K3500 454
BOHICA is offline   Reply With Quote
Old 03-24-2012, 08:02 PM   #5
notsolo
notsolo's Avatar
I like the polyurethane body mounts I have them on my 62 Panel....These have been under the Blazer for 15 Years Zero Mileage. I am close to getting her on the road I hope...
Old 03-24-2012, 09:27 PM   #6
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Looking good Ed
Richard
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 03-26-2012, 02:11 PM   #7
cleszkie
cleszkie's Avatar
Looks good, but you will still get moisture behind that panel with water being flung off the tire. I'd add some drain holes or else you might be providing a nice place for rust to grow and debris to collect between the panel and the outside of the rocker box end. It looks like you made it removable, so I'm guessing that you already planned for periodic removal and clean out.
cleszkie is offline   Reply With Quote
