Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 03-15-2012, 09:30 PM   #1
hayhauler71
hayhauler71's Avatar
Floor Jacks
What kind of floor jacks are you people using. I need to replace my Sears Crapsman jacks that lasted a whole 2 years any suggestions would be great
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 03-16-2012, 09:30 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Floor Jacks
I've got a full sized 3 ton cheapie from NT.I paid about $130 with a pair of jackstands(necessary with this jack).The first one I got leaked down.They replaced it and the new ones worked fine for about 4 years and still going.I wont get under anything without jackstands and so far so good.The new one has never leaked down and they had decent reveiws.Of course I don't use it daily,maybe once twice a month,if I was using it in a commercial shop,I would definitely upgrade.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-16-2012, 10:18 AM   #3
cdowns
cdowns's Avatar
Re: Floor Jacks
i've got a craftsman that is somewhere in the 15-20year old range and also a lightwheight loprofile aluminium jack from harbor frieght that is about 9-10years old that i use on loclearance vehicles
the way i've found to get a jack to last is to jackup vehicle and put on jackstands immediately// the longer you leave the jack loaded with weight the sooner the seals fail
Old 03-16-2012, 04:00 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
Re: Floor Jacks
I have an old Lincoln, and recently bought a Blue Point aluminum jack for lighter stuff. Today, I would go with a Milwaukee or US Jack.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-19-2012, 05:56 PM   #5
NONHOG
NONHOG's Avatar
Re: Floor Jacks
Have you thought about rebuilding yours? Lots of write up on the web.
My Craftsman didn't last worth a darn either.
"I feel the need for speed!"... as soon as I am done with my nap.
NONHOG is offline   Reply With Quote
Old 03-19-2012, 07:39 PM   #6
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Re: Floor Jacks
Here's a good one with pictures. I'm going to try this on a old floor jack I have that won't hold pressure.
http://garagejournal.com/forum/showthread.php?t=51105
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 03-20-2012, 01:44 AM   #7
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Floor Jacks
I cheaped out on a HF with regrets.
Goes up a half inch at a time...or so it seems. Drops like a rock (waits 'til you aren't looking)
Very heavy and very hard to unlock, to lower it.
When my hands are being buggerly, I have to use a pipe wrench to release it.
Yes. Really.
Rolls and looks great!
Hope to someday watch it roll itself down the avenue.
I should have bought a used Snapon and rebuilt it.
Good Luck on whatever you chose!
ETsC10 is offline   Reply With Quote
Old 03-21-2012, 11:46 AM   #8
ERASER5
ERASER5's Avatar
Re: Floor Jacks
I have an old Allied 3.5 Ton. Still works, but the let-off is rather sudden unless you strain your milk controlling the twist on the handle. After dropping my 3/4 ton truck on the disc, it was time to change.
My new 3.5 ton jack is the HB dubble pump unit. Fast and easy to use. Let-off is very controlled. I like it much better than the old one except for the width. This thing is WIDE! I had to set it just right to have it and 2 jack stands under my Crapolier on the same sub frame bar. $200.00, not real cheap, but not real expensive either.
I also have a couple of the small 2.5 ton units, one Craftsman, and one A-Zone one. I would not trust either to support a lawnmower for any length of time. They are good for rotating tires.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-21-2012, 06:19 PM   #9
Re: Floor Jacks
I have 2 3 ton ones. One is a Craftsman that I have had about 10 years. Only issue was that plastic grip handle gave out last year and cheapie me has a dust tape version now.
The other 3 ton one is from Harbor Freight. So far no issues in 2-3 years I have had it.
I have 2 small 1.5 tons, one from sears ((given to me about a year ago. still new in box) and the other I forgot...I think I bought it in Japan (it's about 25 years old). The old one is in the truck all the time and has been used hard over the years, but keeps on tickin.
Old 03-21-2012, 09:34 PM   #10
hayhauler71
Re: Floor Jacks
Well I had to get something so i went with a 2 ton floor jack made from OTC it has a lifetime warranty and the repair center if I need one is 5 miles away paid $200.33 shipped to my door and weighs 43 pounds
Fuzzy
Old 03-21-2012, 10:12 PM   #11
W. Higgins
W. Higgins's Avatar
Re: Floor Jacks
A little late to this but I love my Norco SUV jack:
http://www.hyjacks.net/Norco_2007_08.jpg
You can probably find better pricing if you shop around. That link was just handy. It will actually lift it's rated tonnage and the extra height is very helpful. Many of these regular jacks have such low lift now that the jack barely gets taller vehicles off the ground. In size and capacity it's built like a floor jack from the old days.
W. Higgins is offline   Reply With Quote
Old 03-21-2012, 11:52 PM   #12
Maxxd07
Maxxd07's Avatar
Re: Floor Jacks
Bought a cheap one, an ATD, about 5 or 6 years ago from the only "good" parts store left, and they said it will be great for the money and they were right(they usually are 99% of the time). Never had a problem with it yet and I love the "quick up" about it. About one to two pumps untill it finds resistance then it works like a normal jack. I never leave it supporting anything unless I have to swap a tire out on the wifes ride quick. I have seen too many lucky people walk away from jacks slipping or failing to push my luck.
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 03-24-2012, 07:55 PM   #13
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Floor Jacks
Good looking jack. Congrats!
What's the specs on it & have you tried it yet?
_______________________________
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
Old 03-24-2012, 08:36 PM   #14
truckdude239
truckdude239's Avatar
Re: Floor Jacks
i bought a hf one been 4 years still going strong and it sat out doors for 2 of those years
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 03-25-2012, 08:09 PM   #15
hayhauler71
Re: Floor Jacks
Lifts 2 tons and weighs only 43 lbs! • Dual pump pistons – just five pumps gets you to maximum height of over 18 inches. • Meets ANSI PALD, Part 10, for safety and quality. • Low profile – 3-1/2 inches – makes it perfect for ground hugging, high performance cars. • Weighs just 43 pounds and includes side-mounted handles for quick and easy carrying. • Aircraft-grade billet aluminum provides strength with maximum weight savings. • Two-piece, 45" long handle snaps together for quick set up. • Removable, rubber saddle pad protects vehicle and prevents slipping. • Backed by OTC's Lifetime Marathon Warranty.® I have tried it and it works great very happy with it
Fuzzy
Old 04-25-2012, 03:54 PM   #16
MLB57
Re: Floor Jacks
I have a 25 yr old snapon that is just getting close to replacing, seal leaking probably going back with otc i have one at my shop at work and seems to be holding up ok
MLB57 is offline   Reply With Quote
Old 04-25-2012, 08:56 PM   #17
duallyjams
duallyjams's Avatar
Re: Floor Jacks
I have a mac tool jack for well over 20yrs no problems still going strong my crapsman crapped out after a couple yrs and it's not rebuildable either and so far so good on my HF jack.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-26-2012, 12:22 AM   #18
Torrey72
Rollin in my K5 toaster
Torrey72's Avatar
Re: Floor Jacks
Harbor freight Jacks are to die for... or is that to die from?
Torrey72 is offline   Reply With Quote
