Door alignment
I am starting to put my doors on and I am having a problem getting the fit right. Th rear door when fully closed is not aligning up with the body. It is sunk in more. It looks like the striker is set in too far. I moved it out all the way but no luck. What am I doing wrong to get the proper body line?
Re: Door alignment
Is the front lined up with the fender? I have noticed on some vehicles if you have the front hinge too far out it sinks the back in, normally I see this with two door cars (long doors) but it may be worth a shot checking.
Re: Door alignment
I have the front fenders off. I put it on to check the fit. It seem to be ok but i will check again. Thanks for your help.
![]() Join Date: Feb 2010
Re: Door alignment
Make sure you have your door rubber bumpers on. 2 little rubber pcs that cushion the door from hitting the jamb. You can somtimes close the too far in the striker. Should only be like 2 clicks to close.
#5 | |
Re: Door alignment
![]() Also, you don't need to have the fender on to check the fit of the door, just make sure that the bottom is flush with the rocker, and the front of the door is flush with the windshield post.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Re: Door alignment
You also have the striker adjustment if you are off on that side as well as the 2 rubber stoppers.
---------------------------------------------- 1966 Chevy C10 frame off resto (In progress) 1966 GTO Numbers matching original 1989 Toyota Pickup (Tonka) resto 2002 HD FLSTC 2000 HD FLSTC 1996 Ninja ZX11 ![]() ![]() |
Re: Door alignment
Does anybody have a pic of the bump stops? Mine is missing and need to know where they go. The bottom rear looks like it is bent a little it is lined up in the front. I closed the door and at two clicks the body lines are ok except the slight bend in the bottom door.
Re: Door alignment
Here are some pics, sorry the light is bad. I still think the lower right is bent out a little. Any suggestions?
http://i311.photobucket.com/albums/k...a/IMG_8600.jpg http://i311.photobucket.com/albums/k...a/IMG_8604.jpg http://i311.photobucket.com/albums/k...a/IMG_8603.jpg http://i311.photobucket.com/albums/k...a/IMG_8602.jpg http://i311.photobucket.com/albums/k...a/IMG_8601.jpg |
Re: Door alignment
Here is an ok photo of the bump stops and striker plate. Good luck!
Re: Door alignment
Barnfind...
The '60 thru '63 are different than the '64 - '66....as they use the wedge & slot along with the striker plate....At least I think I'm correct on the year break... I'll take a pic of the bump-stop's that go along with the early cab/door alignment system and post em up for you.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
Re: Door alignment
i would like to see the 60-63 set up also. i am getting ready to pull the doors for repair.
the Stealth Weapons 63 project, all comments, advice, and critiques welcome! http://67-72chevytrucks.com/vboard/s...d.php?t=438235 |
#12 | |
Re: Door alignment
There are no bump-stops on the early design....just the wedge. Give me a few more minutes, stealth.,...I'll get em up.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 Last edited by A.T. RockDriller; 03-22-2012 at 10:35 PM. |
Re: Door alignment
Thanks for all the input. Is it the big wedge under the strike plate? I have the door adjusted good except for the door is going in too far at the rear. I have adjusted the striker all the way out. When I do the two clicks the door looks good but it is not seated all the way. I want to get this fixed so I can put my fenders on. Any suggestions or pics?
#14 | |
Re: Door alignment
Get down and check out that wedge....you can loosen it and use a dead-blow hammer to thump it outward about 1/4 inch....snug it up and see how you like it. You can adjust it in all directions. Someone on here....I think it's Markeb, has the shop manual insert with the step by step instructions on door adjustment. Maybe we'll get lucky and it will just "appear" in a little while........
#15 |
Re: Door alignment
anything on this yet?
#16 |
Re: Door alignment
I moved the wedge and it lines up good. I think the striker or latch is worn. It closes on the two clicks but still doesn't stay lined up. It moves around. Other than that it looks good. I sanded it and sprayed 1st coat of primer. Here is some pics. If you notice you can see the gap is bigger in the rear of the door. I also have the front fender and extender mocked up.
http://i311.photobucket.com/albums/k...a/IMG_8627.jpg http://i311.photobucket.com/albums/k...a/IMG_8626.jpg http://i311.photobucket.com/albums/k...a/IMG_8625.jpg |
#17 | |
Re: Door alignment
If you have any modeling clay or silly putty, you can stick some in the slot and then put a little celophane over it, shut the door.....open it.....and that will give you an idea how far and which way you're going with the wedge.
#18 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Re: Door alignment
A tip for posting pics;
there should be a choice in photobucket for posting in forums. I just changed your links by adding img in place of url. Quote:
#19 |
Re: Door alignment
Lookin good, Barnfind...
Thanks for tweekin it LM65.
#20 |
Re: Door alignment
I've learned that drilling line up holes through the hinge mounts helps immensly when putting the doors back on. Holes no larger than 1/8 inch and lining up with a nail.
Glad you have your doors lined up. |
#21 |
Re: Door alignment
I thought of that before I did it. But as you can see I didn't. I will the next time I do it. Thanks for changing my pics. I switched to photo bucket and did't know how to do it.
