Old 03-23-2012, 06:54 PM   #3601
67cheby
67cheby
67cheby's Avatar
Re: 67 cheby's Dropmember build thread
caught up nothing.....you are flying past me !!
67cheby is offline   Reply With Quote
Old 03-23-2012, 07:06 PM   #3602
jtp67-72
jtp67-72's Avatar
lol......seriously I want your honest opinion on body drop when your done...I looked into that but looked like a lot of work for 3/4 inch--when I 1st heard of it from Nate--I had visions of MUCH lower but then it basically got the pinch welds to touch---JMO!!.......How's jr??.............jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
Old 03-23-2012, 10:12 PM   #3603
68 TT
Still plays with trucks
68 TT's Avatar
The raised panel infill piece looks great. That helps give that big flat area some character it needs when the stock stuff is filled in.
The square body tubs are looking good too. Nice work Mike.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-24-2012, 09:09 AM   #3604
67cheby
67cheby
67cheby's Avatar
i will let you know and of course share tons of pics !
Old 03-24-2012, 09:11 AM   #3605
67cheby
67cheby
67cheby's Avatar
thank you and yes i agree, when Porter came out with that i thought WOW, that really does give the pass side a little something extra !makes it pop !
Old 03-24-2012, 09:13 AM   #3606
67cheby
67cheby
67cheby's Avatar
speaking of that here is the progess on it last night, and then a little progress welding up some of the extra frame holes, and then a pic of the rear at full lift !
Old 03-24-2012, 09:17 AM   #3607
67cheby
67cheby
67cheby's Avatar
i am also in the process of trying to follow N2billets and JTP67-72 lead of tucking the ac unit up far enough behind the dash that it is hidden, the only problem is that i think my unit might be a little bigger, luckily my hoses do come out to the side so i can do this just still trying to figure out what and where the cutting needs to start !
Old 03-24-2012, 09:29 AM   #3608
jtp67-72
jtp67-72's Avatar
Yours is definitely different from mine but looks like it will tuck --my dash is 2 1/2 " lower than stock dash which helps...that hose configuration would have made mine easier..........jim
Old 03-24-2012, 09:35 AM   #3609
67cheby
67cheby
67cheby's Avatar
i am trying to decide if i should slide the whole unit towards the drivers side and then go up ?
Old 03-24-2012, 09:49 AM   #3610
watahyahknow
watahyahknow's Avatar
you could raise the gutterpart above the unit so it can slide up a little more
you can hardly see that on the outside , not sure if the wiperunit would be in the way of that though and you prolly need to make an extra drain for the rainwater
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 03-24-2012, 09:57 AM   #3611
mightymouse
mightymouse's Avatar
hey 67cheby, great job on the firewall
mightymouse is offline   Reply With Quote
Old 03-24-2012, 10:00 AM   #3612
67cheby
67cheby
67cheby's Avatar
raising it up into the gutter is what i am thinking about doing. Thanks mightymouse !
Old 03-24-2012, 10:14 AM   #3613
raull
raull's Avatar
good job mike , moving along , keep it up !!!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 03-24-2012, 02:17 PM   #3614
ddubbs
ddubbs's Avatar
Glad to see your moving along on your truck. Turning out awesome!!!!!!! Hoping to get started on mine today. Pretty excited. Full porterbuilt.
ddubbs is offline   Reply With Quote
Old 03-24-2012, 02:18 PM   #3615
67cheby
67cheby
67cheby's Avatar
thanks, looking forward to seeing your progress also !
Old 03-24-2012, 06:48 PM   #3616
jtp67-72
jtp67-72's Avatar
That "shoe" right above fan motor is what i cut out and refabbed--but it may work if U do move to drivers side a little and up...mock and stand back and take a look.....when the truck is low alot of the underdash clutter disappears....jim
Old 03-25-2012, 11:17 PM   #3617
laid67
laid67's Avatar
i like that A/C unit. seems like the only time my truck is derivable is in the summer when its 100+. and in a black truck no less... the problem is i have to sell a car to afford one. haha great progress man, keep it up!
laid67 is offline   Reply With Quote
Old 03-25-2012, 11:54 PM   #3618
mcbassin
Still Learning
mcbassin's Avatar
Nice work on the firewall Mike. I'm interested in the v/a setup tucked. I am in the process of figuring mine out right now. I never even considered raising it. I probably won't now since I already cut the hole in the firewall. I know you are routing your hoses throught the fender well. I'm not doing that modification. Keep up the hard work.
Old 03-26-2012, 12:21 AM   #3619
YBNORML
YBNORML's Avatar
Firewall looks wicked! Very clean
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-26-2012, 02:49 AM   #3620
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Nice work on the firewall looks very clean!!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 03-26-2012, 09:33 AM   #3621
67cheby
67cheby
67cheby's Avatar
thanks guys ....after much consideration this weekend , i dont think i am going to cut into my the channel to raise the ac unit i can raise it about 2 inches without doing much of anything just a little bracket work so in order to keep progressing and not going backwards with my build (and i am a little scared to cut that part) i guess you will just be able to see mine a little !
Old 03-26-2012, 09:38 AM   #3622
smbrouss70
smbrouss70's Avatar
With the pinch weld on the ground, I'm pretty sure no-one will notice (or even see) your A/C box under the dash.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 03-26-2012, 09:59 AM   #3623
67cheby
67cheby
67cheby's Avatar
LOL, maybe not, i will probably just dye it the color of the carpet so it dissapears !
Old 03-26-2012, 10:48 AM   #3624
YBNORML
YBNORML's Avatar
Nothing wrong with that. Sometimes you just have to know where to draw the line in interest of overall progress. That being said, I haven't learned that yet
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 03-26-2012, 10:54 AM   #3625
67cheby
67cheby
67cheby's Avatar
LOL..i dont really know if i have learned yet, but i think that this is ones spot i will just step back and leave it alone !
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
