Old 03-26-2012, 12:03 PM   #1
fasteddie1964
fasteddie1964's Avatar
neutral safety switch
Anyone know how to hook up a neutral safety switch? (The one on the column)
I got my backup lights working off it. I have two more lugs left on switch. I'm assuming I can run a wire off each lug and splice it into the wire going to solenoid. Does that sound right and if so what color is the solenoid wire on ignition switch?
Friends don't let friends drive Fords
fasteddie1964 is offline   Reply With Quote
Old 03-26-2012, 08:42 PM   #2
fasteddie1964
Re: neutral safety switch
Anybody?
Old 03-26-2012, 10:27 PM   #3
protrash64
Resistance is Futile
protrash64's Avatar
I've only done it on aftermarket shifters, but it sounds correct what you are describing.....solenoid wire should be purple in stock set-ups.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-27-2012, 08:06 AM   #4
fasteddie1964
Thanks Man, I need to get this done. I was working on backup lights and had trans in reverse, some friends came up and I started it for them and about ran over my S-10.
Old 03-27-2012, 10:22 AM   #5
64shortbox
64shortbox's Avatar
Smile Re: neutral safety switch
Yes,
On a 64 one wire goes from the far left terminal on the ignition switch (laying on the floor of the truck - looking up at the switch) to the neutral safety switch then another wire from the neutral safety switch to the starter solenoid. The factory used 12 gauge wire for this.
64shortbox is offline   Reply With Quote
Old 03-27-2012, 06:44 PM   #6
fasteddie1964
Originally Posted by 64shortbox View Post
Yes,
I think that's what did. I just cut the purple wire and wired neutral safety switch in between.
Old 04-04-2012, 04:45 PM   #7
fasteddie1964
Since I wired the switch up, sometimes when you crank truck and pull truck in drive the starter gets activated for a split second. Has anyone ever experienced this happening to them? If so what is causing it?
Old 04-07-2012, 09:00 PM   #8
fasteddie1964
Found the problem, just needed to tweak the adjustment a little.
