Re: Need some rear suspension suggestions.
I am running a wish bone setup. Which is basically a triangulated 4 link. I have the upper and lowers inside the frame. If you search some of the builds, you will find a couple with setups inside the frame rails. Leevon has a really slick setup using the trailing arm setup. If you havent seen his build, you probably should check it out. He has a AD truck, but it may give you an idea. Hope this helps a little.
Posted via Mobile Device |
