#26 |
Re: NP 205 Rebuild and Info
This was seriously one of the best NP205 write-ups I've ever seen. Excellent job jbclassix!
#27 |
Next I installed the linkage
1st Off - I wish I had this post to help me when I did my rebuild last month! 2nd - Do you have any other pics of the linkage/shift rail tie bar? I seem to have some extra washers and a curved "wave washer" and I can't recall how it does back on. I am guessing it goes in the the end of that angled twisted piece and connects the the shifter itself... |
#28 |
Junk Yartist
I think the wave washer goes between the shift bar and flat washer... I just looked at mine, and I am missing it. I will see if I can find it, get it installed, and take a picture. Thanks for pointing that out!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#29 |
Nice thread. You just made it possible for everyone to tackle a complete rebuild. Information is greatly appreciated. Keep up the good posts.
#30 |
Broke and still trying
When I tear mine apart again, i'll be sure to scoot over Redwood Rd and drop mine off! Great job!
#31 |
That previous post was for SeventyOne, JB this is a great post and thanks for all the pics!
#32 |
#33 |
Any update on the linkage JBC?
#34 |
Junk Yartist
Unfortunately, no... I have not done any work on it. I have been working on an Eaton HO72, the 4th door project, and work. I think the wave washer goes on the shift lever. I have some time so I will check tonight!
#35 |
Junk Yartist
OK, so I looked up where the wave washer goes, and if you have the round-bar linkage, the linkage goes on the shift lever, then the wave washer goes against the lever, then the flat washer, then the cotter key. I will see if I can link the adobe picture.
#36 |
Great job on the write up, Thanks!
Is that a stock shift bar, looks a little different than my stock one?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
#37 |
there are I think 2 different types.
#38 |
Born Psycho
![]() Join Date: Feb 2001
i just added this to my "favorites" list.
great info, thanks a bunch. you are doing some awesome work.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#39 |
One of the First
![]() Join Date: Jan 2000
Can you recommend a good (not chinese-
![]() Good stuff, I'm just starting on a rebuild. ![]() Thanks DP
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#40 |
Great thread thanks a ton
#41 |
![]() Join Date: Mar 2012
Thanks a ton, i will be using this this winter when i do a sm465 and np205 rebuild!! Invaluable!
1988 Chevy Crew Cab 1ton 4x4 SRW LWB 1977 Dodge 1 ton 4x4 My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=516872 ![]() |
#42 |
Awesome thread, thank you!
#43 |
Junk Yartist
I'm glad that everyone appreciates this thread! I guess I should let everyone know why I haven't installed the yokes and adapter yet. Some of you may know that in September I was in an accident during my move from Colorado to California. Unfortunately I was unable to tow the trailer with all my stuff in it the rest of the way, so the trailer, and everything in it, are in storage in Colorado. The t-case, the suburban it goes in, all my shop tools, everything.
Hopefully I will get out to CO this year and finish this up for all you!
#44 |
since the 205 is super common and this is a good resource ill add what i know to be true. please feel free to add your input.
keeping this to 69-72, 73-87/91 big body pickups ALL crew cabs were fixed yoke. regular cabs with carrier bearing were fixed yoke. post 1985 np205 regular cabs are slip yoke. all 1980 tcases were 205s. most slip yokes. all rear output shafts are 32 spline. fixed and slip. both slip and fixed yoke can be swapped with just removing the 8 bolt housing and removing as an assembly. also between chevy ford dodge and international. speedo and breathers just change. vss introduced in 1990. all 205s were figure 8 front pattern until 1985. 1985 introduced the round pattern 205. i think 73 the speedo cable moved to passenger side. several assortments of shifter styles. 1985 also introduced the W and S crossmembers to be used with short adapters and one piece rubber mounts. pre 1985 one ton 205s had a flatter crossmember than 1/2 and 3/4 tons. pre 1985 1 ton crossmembers went INSIDE the rails. pre 1985 1/2 and 3/4 tons went below the rails. the common/early sm465 version of the 205: figure 8 pattern face ten spline input male small input bearing ten spline front output if it has the spicer CV. 30 spline front output for the later flanged cv front driveshaft. uses the taller two footed adapter the other/later sm465 version of the 205 found post 1985 round pattern face 32 spline female input gear. with the BIG bearing case. LONG input gear, around 4". not short th400 style. 30 spline front output flanged uses the short foot adapter with one piece rubber mount th350 version 27 spline male input gear. small input bearing figure 8 pattern only offered. tall adapter. can be used to put behind a 700r4. early th400 version figure 8 pattern face 32 spline short input gear, 2" ish. large input bearing strongest for offroad applications especially doublers later th400 version found 1985 and newer round pattern face long input gear same as later 465 version. same large input bearing 30 spline flanged front output. this is what you want for putting it behind an nv4500. use a pre 1985 short th400 input gear if you dont want to use the advance adapter spacer. but thats a whole nother can of monkeys. 4l80 version 1991 only round pattern face large input bearing does not share same adapter as th400. has its very own adapter same long input gear VSS ford international and dodge np205 they have a 32 spline front output shaft these all swap over to GM cases to enable larger/better yokes to be installed. Last edited by obijuan; 10-27-2012 at 07:13 PM. |
#45 |
The holy grail of NP205 information!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#46 |
Junk Yartist
Thank you, and thank you obijuan for your contributions.
I will be adding more info as time goes on. Please do the same!
#47 |
Is there any info. on the seals and how they are installed for the adapter that bolts to the trans? Seems this is where mine is leaking
Help? Thanks for taking the time jbclassix
#48 |
On the transmission side of the adapter there is a groove for a rubber o ring.
Posted via Mobile Device |
#49 |
There are also two regular type seals that are in the adapter for the coupler outer seals. The inner is the o ring. This keeps fluid from your trans from going into your t-case.
#50 |
its been a while...but this is a super quality thread...lots of work went into it!
I am not exctly up to par on the level required to do this...but I just got a rebuild kit for my local shop that is familiar with such. it was very informative to actually see whats going on... I can do most on my 67 CST...but we all have our limitations... ![]()
ted cruisin in my '67 K-20 '67 Custom Sport Truck '55 Chevrolet 3100 w/ 235 il6(Powermaster) '63 Chevrolet 1/2 ton 250 il6 '65 Chevrolet 1/2 ton 283 V8 |
