03-26-2012, 02:35 PM | #1 |
Test start on a 305
Trying to test start my 86 305 c10, restoring my truck, i have the frame and and four tires and the motor and trany in the frame, and i wanted to crank the motor before i bolt the cab on, i put a hose on the trany lines so they don't spray all over, The drive shaft is slid in the tranny, i put the crank on TDC/ piston at the top of cylinder on #1, hooked gas lines up to a spare tank iam getting fuel, i hooked a wire to the distributor 12v red wire, to my battery, wired the starter, is this how i would crank the motor ??
03-27-2012, 11:09 AM | #2 |
Re: Test start on a 305
I wired it up and hit the starter, and it fired right up |
03-27-2012, 05:55 PM | #3 |
very nice
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
