Old 03-20-2012, 11:04 AM   #1
ABX131
ABX131's Avatar
63' stock gas tank question
My truck has a bad gas tank and came with a replacement one to switch it with. Can you take the rubber grommet around the filler off with out destroying it or is it just better to get a new one ahead of time?..
ABX131 is offline   Reply With Quote
Old 03-20-2012, 11:13 AM   #2
austin60c10
austin60c10's Avatar
Re: 63' stock gas tank question
you shouldn't have to take the grommet out, just unhook the hose at the tank side and reattach there, be sure to check it and replace the hose if it is bad they are a pain to get to when the tank is in.
austin60c10 is offline   Reply With Quote
Old 03-20-2012, 03:10 PM   #3
chainsaw
chainsaw's Avatar
My rubber gasket came out fine with the filler neck and tank still installed and it was dried up. I hear it wont go back on without removing the neck.
chainsaw is offline   Reply With Quote
Old 03-20-2012, 03:52 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
That is true.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-27-2012, 09:26 PM   #5
chainsaw
chainsaw's Avatar
I just got my new gasket , used a screwdriver and pushed it back in place with the tank and neck still installed. It fit flush, Ill have to wait and see if it stays down or not.
Old 03-27-2012, 10:42 PM   #6
LoudLowNslow
How can you tell if the original in can tank is bad? I think mines original, truck hasn't run in 10 years..
1966 GMC stepdside shortbed- needs some love
LoudLowNslow is offline   Reply With Quote
Old 03-27-2012, 10:48 PM   #7
ABX131
ABX131's Avatar
I was told when I bought the truck the gas tank had a leak when filled more than half full and was provided with a replacement...
Old 03-27-2012, 11:01 PM   #8
Rich 5150 69
Rich 5150 69's Avatar
If its loose around the neck of the tank and your pumping gas and overfill it will run right on down into the cab, a potential bomb if you smoke or have a short in the cab.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-27-2012, 11:13 PM   #9
chainsaw
chainsaw's Avatar
It took alot of pushing but seams to be tight as the old one. It probably would have gone on easier with some kind of lube, I just didnt use any.
