Old 11-10-2011, 12:03 PM   #1
pat386
misshape grape
pat386's Avatar
let's talk steering columns.
I have a 35" tilt column that was put in my truck by the previous to previous owner. I know(assume) it's not factory (83' Scottsdale) as it has cruise and wipers on the stalk.
My truck also has a dash wiper switch.
Is there a shorter tilt column that will swap with relative ease? At a junkyard we found tons out of all 80's GM vehicles, but nothing quite will fit perfect. I believe mine is out of a suburban. Just want to have a little more room. thanks!
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did..
pat386 is offline   Reply With Quote
Old 11-10-2011, 12:27 PM   #2
menace121978
menace121978's Avatar
Re: let's talk steering columns.
X2 great question pat! was going to start researching this very topic today
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 11-10-2011, 12:46 PM   #3
pat386
misshape grape
pat386's Avatar
My brother and I tried 80's s10 blazer, 80's cadillac sedan, they were shorter but not a direct swap
Old 11-24-2011, 06:47 PM   #4
pat386
misshape grape
pat386's Avatar
My 83. Now with 3 inches less of steering column.
Old 11-24-2011, 08:12 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
So what did you do Pat, Find the seat slider lever ?
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 11-24-2011, 08:25 PM   #6
pat386
misshape grape
pat386's Avatar
haha! My brother shortened a c10 column. Used a s15 jimmy shaft and had to do some welding for brackets. All in all, it feels better!
Old 11-25-2011, 03:58 AM   #7
menace121978
hey pat, could i get some details on the steps took to do that mod?
"Dennis the Menace"
Old 11-25-2011, 05:06 AM   #8
pat386
misshape grape
pat386's Avatar
I will get have to get with my brother and get more detail. But I do know the shaft and tilt mechanism is out of a s10/s15 blazer/jimmy, nuts for the mounting bracket were welded on 3 inches higher, and the ignition switch had to be moved.
I think the external housing of the column was collapsed, and you could probably use a c10 shaft as long as you collapse it. We used the tilt top out of the blazer as we didn't want to tear my good tilt column apart so I have a spare. We might experiment with a cadillac tilt/relescope column. But the telescope feature kind of takes away from the column shortening anyways haha
Old 11-26-2011, 08:54 AM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
nice work I'd like to see how it was done too pls
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-28-2012, 12:15 AM   #10
FlossyB
I would love to have a steering column that short, but no idea how to accomplish. Would a custom built one work from Flamming River or someone else? I'm thinking tax return money might not make it so bad.
FlossyB is offline   Reply With Quote
