Old 03-28-2012, 09:34 AM   #1
rs72z
rs72z's Avatar
Re: 700R4 2WD vs. 4WD
Originally Posted by 68vert View Post
Hello,
I have a '75 Blazer with a 3 on the tree, and I'm looking to change it to an automatic. I have a bead on a cheap 700R4 out of a '91 GMC 2WD. What needs to be done to put this in my Blazer?
Can I basically remove the 2WD tailshaft, install a different output shaft, and bolt it to my transfer case?
Thanks in advance for any help or advice.
Brian
Nope. You have to tear the trans all the way down and replace the output shaft.
___________________
78 ccsb dually
5.3
4l60e
http://67-72chevytrucks.com/vboard/s...d.php?t=491551
rs72z is offline   Reply With Quote
Old 03-28-2012, 09:47 PM   #2
86 K-10
86 K-10's Avatar
what he said...now go here ->http://www.transmissioncenter.net/700r4.htm
86 K-10 is offline   Reply With Quote
Old 03-29-2012, 06:56 AM   #3
BigBlocksRule
No, you don't. That's one nice thing about the 700R4 and 4L60E - you can swap the rear shaft and tailhousing and make it a 4WD unit without a complete tear down.
That said, I wouldn't run a 700 on anything that made a lot of torque or was used for hauling or towing.
There are quite a few vendors now selling stand-alone computers for the 4L80E. It'll take anything you can dish out and more.
BigBlocksRule is offline   Reply With Quote
Old 03-29-2012, 07:54 AM   #4
rs72z
rs72z's Avatar
Yea, the only thing you dont have to pull out is the low/reverse clutches.
___________________
78 ccsb dually
5.3
4l60e
