Old 03-28-2012, 02:18 PM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: Rocker and inner panle design
^ I agree. No need to re-invent the wheel to solve a problem that is usually maintenance related. As said, make sure all water mitigation devices are in working order ( i.e. weatherstripping, gaskets, sealers, etc.) Next, when you do replace the rockers, kicks, corners, supports and pillar bottoms- spray or brush everything you can get to with a good rust inhibiting coating. use weld-through primer where you have to plug weld. Do those things and you should be good for another 20-40 years.
Remember- Mother Nature and time will destroy EVERYTHING........eventually!
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
