03-28-2012, 03:30 PM | #1 |
Seam Sealer in the Bed question
i have noticed that the seam sealer in the bed is cracked and hell, lets me honest, coming loose. What is the correct stuff to use on this. I ma looking to remove all the existing sealer and start all over before lining the bed.
Thanks T
85 Silverado SWB |
03-28-2012, 04:05 PM | #2 |
Re: Seam Sealer in the Bed question
i belive that 3m makes a seem sealer and there is a bursh on and i think one for a gun too
03-28-2012, 04:27 PM | #3 |
That was a good question i am getting ready to do the same thing let me no how it turns out and which brand you use.With some pics if you take some.
03-28-2012, 04:36 PM | #4 |
I have done several. Clean out all the old caulk, wire brush or grind any rust out in the seams, and apply a rust sealing paint to the seams. Then reapply the seam sealer (3m fast n firm and Crest qwik-seam are both good). I prefer the type that uses a caulk gun for these areas. You can use paint thinner on a small brush to smooth any areas needed (or wax and grease remover). Hope this helps.
Steve |
03-28-2012, 04:37 PM | #5 |
u must have used some type of laytex sealer i use 3m ultra pro it is a urathane stays flexible and sticks very well still good on my box must be goin on 17-18 years
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
03-28-2012, 07:34 PM | #6 |
A guy at work was patching his floor in a 69 nova & got a tube from O'Reilley Auto Parts,Expensive but works great. It was a tube like for a caulk gun & went a long way...
Hope this helps Mike 1985 SWB Silverado 355 ci 375hp+ (installing) 700r4 (installing) |
