#3026 |
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Drew, did those seats go nin fairly easy, or was quite a bit of fab required? Looks great!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#3027 |
I've been following this build for quite awhile and as everyone else has said, awesome job! You have me motivated to get started on mine. My brother has been in the body shop business for 40 yrs. so I know what kind of skill it takes to do something like this. You are truly a master craftsman. I hope I can get to Pigeon Forge, but if I don't, I may just cruise to Memphis someday. I'm only a couple hours away. I would really like to see your truck in person.
David ![]()
69 C10 LWB (SWB now) |
#3028 |
Lucky Teter at the wheel
The seats are bolted directly to the floor and I have a post showing exactly where to drill the holes.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#3029 |
I worked on my hide-a-dash tonight and welded studs to the mounting plate. Here it is just sitting in the glove box hole. I need a plexiglass faceplate and I will cover the green metal in upholstery.
The idea here is to have all the modern information available, but usually out of sight behind the glove box door.
#3030 |
Still plays with trucks
Why not cover the whole thing with a single piece of plexi with the area over the metal painted black from the back side so it blends in with the gauge face.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#3031 |
Collector of Projects
You should add a fake steering wheel on the passenger side... just to mess with everyone....
#3032 | |
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#3033 |
I can't get to the backside to mount it, but with the metal plate and studs I can put it together on the bench and then mount the metal plate from the front. A picture will help visualize when I finish it.
#3034 |
67cheby
![]() Join Date: Sep 2008
cool idea, will any of the guages on the drivers side work also ?
#3035 |
Eventually when I can afford it, yes.
#3036 |
67cheby
i see !
#3037 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice work Drew! For the older gauges, can't you just install the factory sensor and oil pressure line in ports in the engine? Or are there no extra ports on these newer engines?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#3038 |
Yes, oil pressure can be tapped off of a plate on the engine. Volts are also easy. Spedo is not. Gas gauge is not.
#3039 |
I hope that you can't tell what I have done today.
Invisible bra for the rock chip prone hood. And I'm legal now!
#3040 |
Chevy Enthusiast
Sweet, I really like that idea!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#3041 |
Still Learning
Looking great Drew!
#3042 |
ID tag looks great! You didn't remove it did you?
#3043 |
Of course not! I pulled the edges up slightly so I could fully sand and paint behind it.
#3044 |
hmm.... not sure if those weights are correct ... anymore
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
#3045 |
Really bummed, but I think I was sent the wrong carpet set.
I ordered a high hump kit and it says on the box it is for the "400 transmission", but its too short in the front from side to side. The rear of the front piece seems to be wide enough (pics 3 &4) but the front that goes over the high hump ends up being 2 inches too narrow at my passenger kick panel. Do you think they will send me a replacement?
#3046 |
67-72 parts collector,…
![]() Join Date: Nov 2002
The last carpet kit I got was about 2" too long at each door opening.
It had to be trimmed to fit. I believe it came from Brother Truck Parts. (not sure of the brand) I would send that back. Order for a 4x4 burb or 4spd manual trans and you will get the high hump version for sure. Most companies just specify low hump or high hump.
#3047 |
![]() Join Date: Oct 2009
Interesting. Last year I bought a carpet from ACC for my low hump, and it was too full over the hump. I ended up putting a couple of extra layers of padding over the hump to fill it out. Looks like their molds aren't too accurate.
1971 C10 Longbed, 350/TH350 |
#3048 |
About 6 years ago I got the ACC carpet for my 72 suburban with the high hump. It was also about 2 in to short on the ends. I sent it back and the next set was about 1/4 inch to short. Same carpet number on both sets. Everything in the back fit really well.
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
#3049 |
![]() Join Date: Apr 2008
ACC has always been known to make nice replacement carpets- hope they work with you
#3050 | |
Not quite as short as yours so my sill plates just barely covered the edge of the carpet (like 1/16" under the edge barely). I should have sent them back as the edges come out from under the sill plates when I vacuum the car out.
