Old 03-13-2012, 05:58 PM   #1
lmac1210
lmac1210's Avatar
Seats??
There are probably a hundred posts on this I just haven't been able to find them so I am asking for some help! My bench seat in my 1970 SWB GMC are completely shot! I might just order the cushions and upholstery, but wanted to know if there are more options? Like what year seats will fit into a 1970 GMC? Can I find a better seat accommodations for my truck than the original? Perhaps a 60/40 split or even some buckets that will work better? Just thought all the wisdom on this site might lend me a few seconds of advice.
Thanks for any help!!!!
Mac
1970 GMC SWB
1971 Chevy C-20 Longbed
Driving Miss Maybel:
http://1970gmctruck.wordpress.com/
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=513475
lmac1210 is offline   Reply With Quote
Old 03-13-2012, 06:10 PM   #2
425HP409
425hp409
425HP409's Avatar
Re: Seats??
The seat from an 88 and up truck bolts right in and is the same width as the original. You can use some of the original holes and have to drill some.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 03-13-2012, 06:48 PM   #3
lmac1210
lmac1210's Avatar
Re: Seats??
I am pretty new at all this and am unsure about drilling (and I have heard some people say "use shims") so I am kind of scared
When you say drill do you mean just drill and then add a bolt and nut...or something else.
Thanks for your input! Really!
Mac
1970 GMC SWB
My build thread:
Old 03-13-2012, 08:52 PM   #4
lmac1210
lmac1210's Avatar
Re: Seats??
Either my post isn't interesting...or I don't have any friends
......sigh!
Mac
1970 GMC SWB
My build thread:
Old 03-13-2012, 09:55 PM   #5
okyankee
Re: Seats??
as soon as i find a seat, i will do the same in my 67 i just got. i put buckets in the 95 swb i had. i believe some holes line up, i just had to mark where the other holes needed to be and drilled it. i got some grade 8 bolts, washers and lock nuts. grade 8 is probably over doing it, but the safer the better.
okyankee is offline   Reply With Quote
Old 03-13-2012, 09:58 PM   #6
Daddy Brim
Daddy Brim's Avatar
Re: Seats??
If you need to drill new holes for seats, use a good quality nut and bolt. You will also need to support bottom side of cab with something like a fender washer, it is a large washer with a small hole for the bolt. You want the seat to stay put in case of accidents.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 03-13-2012, 10:08 PM   #7
okyankee
Re: Seats??
yes, like daddy said, and i forgot to say, use fenderwashers.
Old 03-14-2012, 02:27 AM   #8
MrSchaeferPants
MrSchaeferPants's Avatar
Re: Seats??
Keep in mind, if you were going to spend some coin on a nice new set of seats, depending on quality, you'd spend about the same professionally reupholstering, if you did want to keep your old seats. But, if you scouted CL for a deal on some seats, that would be far cheaper. Or, if you wanted a 60/40 split bench, go measure and see if it'll fit, you can always adapt the seat mounts, or drill holes. Get some plush velour fully electric 60/40 from a Cutlass Supreme Brougham Myriad of possibilities.
68 GMC C2500 - 305 V6 - 4spd
MrSchaeferPants is offline   Reply With Quote
Old 03-14-2012, 08:43 PM   #9
Roostboy102
Roostboy102's Avatar
Re: Seats??
I paid $100 for a rear seat out of a newer super duty! No signs of wear same dimensions had 2 drill but I couldn't be happier! Search cl and take a tape measure with you.
Roostboy102 is offline   Reply With Quote
Old 03-14-2012, 08:50 PM   #10
okyankee
Re: Seats??
pic?
Old 03-14-2012, 08:54 PM   #11
Roostboy102
Re: Seats??
Originally Posted by okyankee View Post
pic?
I don't... I'll try to get 1 in the next couple days
72 C10 - Multicolor, 4.8 ls, NV3500. Sold
72 K5 - Under Construction
Old 03-14-2012, 08:59 PM   #12
okyankee
Re: Seats??
cool. thanks.
Old 03-20-2012, 08:40 PM   #13
Roostboy102
Re: Seats??
Out of a newer Super Duty not sure what year? Nice n firm, fits very well! Sorry for the crappy pic and the angle it's in the garage right now gettin torn down.
Old 03-20-2012, 08:49 PM   #14
bbadfred
bbadfred
bbadfred's Avatar
Re: Seats??
late 80s 60-40 w/folding arm rest, re done in leather.
bbadfred is offline   Reply With Quote
Old 03-20-2012, 08:49 PM   #15
lmac1210
lmac1210's Avatar
Re: Seats??
That looks pretty good!
Just had a buddy give me a 60/40 out of a 90 Chevy I just have to make a 3 hour road trip to pick it up.
Mac
1970 GMC SWB
My build thread:
Old 03-20-2012, 09:31 PM   #16
okyankee
Re: Seats??
this is the one i ended up with. i like the fold down console. it looks brand new. i assume the owner had a cover on it.
Old 03-21-2012, 12:50 AM   #17
kevmcrae
kevmcrae's Avatar
Re: Seats??
I originally had a mid 80's bench when I bought the truck. Frankly, it sucked!
So I measured and searched salvage yards for size and comfort as I have a very picky lower back. Ended up with an electric 60/40 seat from a 2006 Yukon with built in shoulder belts. Was a huge step up. But after a few months I got tired of feeling cramped. The seat back was just too thick and crowded the cab room. So went on the search again while I was restoring her. This time I decided to NOT look at built in shoulder belts because the seat backs were just all too big. Ended up with an electric 40/20/40 seat from a 2003 Dodge Ram PU....with lumbar adjustment. Took some cutting on the seat frame and a little welding to add some bolt tabs. But was worth it! Now I have plenty of room and a very comfortable seat with plenty of adjustments to play with for comfort. I am going to either remove the head rests, or shave the front and back because they prevent the seat from going back to where I need it, (6'2"). They are dark grey now so looks okay with my interior. But going to have them recovered next month to early 70's period heavy black vinyl with black and white houndstooth inserts.
Here's both the Yukon and the Dodge pics. (oh yea, new smaller steering wheel helps too!)
kevmcrae is offline   Reply With Quote
Old 03-21-2012, 03:58 AM   #18
96232
Re: Seats??
Mine has buckets out of a 94-98 gt mustang, I will post pics of it when i get some, BTW it is rough, did not pay much for the truck
96232 is offline   Reply With Quote
Old 03-29-2012, 03:50 PM   #19
68 TT
Still plays with trucks
68 TT's Avatar
Re: Seats??
I used the full bench out of an 88-94 vintage Chevy regular cab so it folds forward for fuel tank access.
Fits great and is very comfortable for a bench seat.
I reinforced the underside of the floor with a section of 1/8"x2" flat bar connecting both the new holes together.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
