Old 03-29-2012, 06:54 PM   #1
haasvmc
z'ing a frame
can i get some pics on z'd frames.im not sure on where to cut and if i need cut it at an angle. i could also use some advice on what problems to look out for when doing this.
haasvmc is offline   Reply With Quote
Old 03-29-2012, 08:41 PM   #2
yunkyarddog
yunkyarddog's Avatar
Re: z'ing a frame
help him (so i can go to the drawing board myself)
Im stright up ESL student........ fixin my truck a trip to the yunkyard at the time
94 s10 4x4 4.3/5speed (dd)
68 lwb GMC 350/4speed
52 5 window GMC I6/4speed 12v (8lugs and long bed)
53 bel air 235 I6/powerglide
yunkyarddog is offline   Reply With Quote
Old 03-29-2012, 10:16 PM   #3
L&L70
Re: z'ing a frame
just cut it between the trans cm and shock mount. I cut mine on an angle to push forward 1" while going up 3". I dont know the angle, cause I just layed it out on paper and transfered the points with a punch. Obveously the trans mount, steering shaft, core support mounts, brake and fuel lines, shift linkage, ect.... all have to be addressed.
L&L70 is offline   Reply With Quote
Old 03-29-2012, 11:53 PM   #4
edhtrd71
Re: z'ing a frame
You will probably get some good advise soon. We have cut a few trucks and havent used the z method. I prefer to straight cut and reweld and then plate the frame. There are different methods some cut a diamond and weld it or you could box the frame as far as possible which will help rigidity.
edhtrd71 is offline   Reply With Quote
Old 03-30-2012, 03:02 PM   #5
DaBigKahuna
DaBigKahuna's Avatar
Re: z'ing a frame
Cut at an angle. if you gut on 90s, all the force will be concentrated in the corners instead of being spread out across the welds. The PO of my '26 Zed it on 90s and the frame cracked.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=513812
DaBigKahuna is offline   Reply With Quote
Old 03-30-2012, 06:54 PM   #6
SCOTI
SCOTI's Avatar
Re: z'ing a frame
I would think it depends more on who did the welding than an angled cut vs. a straight/90° cut. Staggered or offset/'Z' cuts do offer more weld area vs a straight cut which would (could/should?) be better for a novice....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-31-2012, 09:25 PM   #7
mike nutt
69fatmotor
mike nutt's Avatar
Re: z'ing a frame
i z'd mine 3" . i cut mine straight up and down to avoid moving the spendle center line forward.
mike nutt is offline   Reply With Quote
Old 04-07-2012, 06:00 PM   #8
yunkyarddog
Re: z'ing a frame
got more pix?
