Old 03-29-2012, 10:29 AM   #1
chainsaw
chainsaw's Avatar
window fuzzies install
On a 65, is there any order on which to install first so the rest of the pieces go on smothley ? It looks like if I put the vent piece in first it will make the fuzzies harder to install, or am I just over thinking this? Thanks. Also any tips on pushing the vent fuzzies all the way down, the window is still in the truck.
chainsaw is offline   Reply With Quote
Old 03-30-2012, 09:05 AM   #2
1963c-10
1963c-10's Avatar
Re: window fuzzies install
I used a straight slot screwdriver and just took my time. Started by the vents and worked my way to the rear of the door. The will push in with a little effort.
1964 Short bed trailer
Old 03-30-2012, 09:40 AM   #3
chainsaw
chainsaw's Avatar
Did you cut the end of the fuzzies where they curve up at the back of the door? I cant seem to get them to go under the door channel rubber. It seems if I cut off 1/2 '' to 1'' they would stop just before the rubber, be alot easier to install and still keep the window from rattling.
Old 03-30-2012, 09:57 AM   #4
1963c-10
1963c-10's Avatar
I didn't have to cut mine. But if I had to trim them I would. The problem is there are som many differnt companies selling them that they are all different. If they need trimmed, Id do it.
