Need a new rear yoke... Help please!!!
So I am starting to go through rear straps on my 1972 chevy blazer. I know the rear is a 12 bolt, but I am wanting to upgrade from straps to u-bolt style. Local part houses, are of no help so I need to order online.
I need to know how many splines the pinyon shafts are. Also I know factory it came with a 1310 ujoint. Right now I have a 1 ton tom woods driveline. But am using a crossover rear ujoint. If I can I would like to take that ujoint to a full 1350. So anyone know what I need to get inorder to get away from straps and go to a 1350 ujoint? My biggest hang up right now is the spline count. Also I am aware that the set up uses a crush sleeve and what I need to do there... Thanks a ton.
Confidence is the feeling we have before we fully comprehend the situation |
Re: Need a new rear yoke... Help please!!!
I got mine off of ebay. It was a spicer unit (don't have the P/N with me) but I found this one as well
http://www.ebay.com/itm/12-Bolt-Chev...ht_1368wt_1222 |
So it is 30 spline. Also what size is the pinyon nut? Socket size? Do they have a kit with a new pinyon nut included?
Would this one work even though it says its for a car? http://www.ebay.com/itm/64-72-Chevy-...e3b33d&vxp=mtr
My kit came with the nut and washer as well. It may have even come with a new crush sleeve, I can't remember cause I rebuilt the whole rearend. I'd just message them and ask.
I've had different size pinion nuts in the range of 1-1/16 to 1-1/4. |
Junior Member
I got mine from a driveshaft place.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
I bought Moroso U Joint Girdles from Summit racing after I blew the caps off my rear yoke, sheering off the cap retainer nubs. Never had a problem since. and for $30 I couldn't beat it. I'll take a pic when I get home. Here's a link
http://www.summitracing.com/search/?...0girdles&dds=1
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
They're super easy to install and you don't have to remove the yoke
I think part of my failure issue is front the yoke being wore out a touch. Is the pinion for the car same as the truck/blazer?
If so this should work... http://www.ebay.com/itm/64-72-Chevy-...e3b33d&vxp=mtr
Here'sthe pics of mine. Here you can see where the tab broke off mine.
I've had mine on for 11 yrs but spent 8 yrs sitting
I am also in need of this 1350 yoke for a 12 bolt.
Did GM use this on any factory applications? |
