03-29-2012, 09:52 PM | #26 |
Collector of Projects
Re: LS factory cruise control hook up
I grabbed two 4 wire switches from the junk yard.. but I couldn't find a good lever assembly....
03-30-2012, 08:57 AM | #27 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-30-2012, 10:45 AM | #28 |
Thanks you have answered many questions!
03-30-2012, 11:18 AM | #29 |
Mine is hooked up and working! now for a long road trip!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-30-2012, 01:40 PM | #30 |
Right on!
03-30-2012, 02:07 PM | #31 |
Do I need to wire just the TAC or the PCM also?
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
03-30-2012, 06:19 PM | #32 |
Just the TAC, provided your PCM is already wired up, brake light switch input, that sort of thing.
03-31-2012, 10:02 AM | #33 |
Future TOTM Winner
Aren't those levers pretty expensive. IIRC those are the ones LMC sells for $230. I have one that came out of a 1980 Suburban but it is pretty rough. Where did you get yours and where did you get the sheet of labels???
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
03-31-2012, 01:55 PM | #34 | |
I had the labels made, if you want one, id sell you one for. $7 shipped. Posted via Mobile Device
04-01-2012, 03:16 AM | #35 |
Future TOTM Winner
I will probably take you up on that, let me dig up my old lever and see how many wires it has and if it is usable. Thanks!
04-01-2012, 04:07 AM | #36 |
Second Chance Program
Subscribed!
04-01-2012, 10:16 PM | #37 |
so in order to run cruise with an on off toggle and a momentary switch i need to run a jumper wire with 12v from the on off switch when its on to the middle of the momentary switch ?
04-02-2012, 03:18 AM | #38 | |
I have a momentary push button that provides 12+ to terminal B when pushed to set cruise. If i hold the button in it will coast until i release the button. Terminal C i remove, everything else is the same as posted. |
04-03-2012, 10:21 AM | #39 |
I will probably end up with a Summit Racing aftermarket column.... for now I have the factory NON-tilt auto column shift.... So I need the one with the hole for the screw....
What did these come out of again.... 3 or 4 wire doesn't matter... |
04-03-2012, 04:22 PM | #40 | |
Future TOTM Winner
04-03-2012, 05:42 PM | #41 | |
How bad is it? I might be able to fix it, I've fixed some pretty nasty looking ones. Or if you get a new one and the old one isn't all that bad, I might be interested in it.
04-08-2012, 05:36 PM | #42 |
Hey guys my cruise lever has 4 wires at the connecter Red, Brown, Green, Yelow. Pretty sure it is from Van tilt column.
I need help making the conections to my '99 Silverado cruise module. I have transplanted the '99 5.3 / 4l60e, fuse block, and instrument cluster. Appreciate your help http://67-72chevytrucks.com/vboard/a...1&d=1333917353 Just need help with figuring out wich wires go were. '99 Crusie Module Connecter: A Gry 397 On switch Output B DkBlu 84 Set/Coast switch signal C Gry/Blk 87 Resume/Accel switch signal D Brn/Wht 379 Clutch pedal switch output E Blk/Wht 451 Engine control module ground F Brn 41 Fused Ignition3 Output G LtBlu 1320 Fused stop lamp feed H Not used (no "I" position) J LtBlu/Blk 396 Signal engage K DkGrn/Wht 817 VSS |
04-08-2012, 06:18 PM | #43 |
That's a switch from an aftermarket cruise control. They are usually normally closed switches and you will need to use relays to reverse them. Ackattack's thread that I have linked in my first post has instructions on how to do it. As for what wires to use for each function, you'll just have to test them to find out. You can do it with a DVM or a test light and a battery.
05-10-2012, 01:54 PM | #44 |
I got mine wired up _ but it is not working. Mine is DBW, does it need to see speedo input to work.
05-10-2012, 03:21 PM | #45 |
It has to have a VSS signal if that's what you're asking. You don't need an actual speedometer hooked up. Do you have both brake switch inputs hooked up? And do you have brake lights? It needs to see ground through them.
05-14-2012, 01:42 PM | #46 |
Pic for farmtrucks. This is a factory pigtail for the cruise switch. The gray wire is the on/off and goes to pin 14 on the TAC. Green is resume/accel and goes to pin 5. Blue is set/coast and goes to pin 4. Pink is the ignition power to the switch.
05-14-2012, 09:50 PM | #47 |
I have a 2005 LS2 with E40 computer DBW. Cruise does not work.
I think the problem is that the cruise is interlocked with the e-brake. The ECM has to see that the e-brake is off for the cruise to engage. (I know this is true on my 08 LS3). Problem is that the BCM reads the e-brake switch and puts the message on the low speed serial bus which the ECM reads. (The same problem occurs for the case learn procedure. The TECH II has to see that the e-brake is on in this case for it to run the procedure.) I am in the process of trying to get a BCM wired up with a toggle switch for the e-brake. No success yet. Has anyone gotten cruise to work with DBW??? TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
05-29-2012, 08:29 PM | #48 |
GM ONLY BABY!!!
Would 1 of these type cruise levers work with 01 6.0 DBW and cruise module? http://www.ebay.com/itm/1971-72-CADI...5e7c01&vxp=mtr
It only has 3 wires, black, blue, and brown.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
05-29-2012, 10:34 PM | #49 | |
If you want one of the ones I have pictured I have a few I would sell. Posted via Mobile Device
05-29-2012, 10:54 PM | #50 |
GM ONLY BABY!!!
Ok. Thanks. I would be happy just pushing the button and the cruise would be set. I don't need the fancy on/off or accel/resume.
