03-31-2012, 07:14 PM | #1 |
Tightened Tilt Column - extra part!
I've tightened up the tilt column on my 90 Suburban, but I have a part - spring clip -left over. Saw it fall, but don't know where from. Anybody? Thanks.
04-01-2012, 01:46 AM | #2 |
Re: Tightened Tilt Column - extra part!
i believe its # 38 in the exploded view below
the image is of a chevelle column but that part matches the suburban column i just could not find a good image #46 here http://67-72chevytrucks.com/vboard/s...50&postcount=2
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=511830 Last edited by tobiahr; 04-01-2012 at 01:47 AM. Reason: found better link |
04-01-2012, 06:14 AM | #3 |
Thanks so much. I think that'll help.
04-01-2012, 02:24 PM | #4 |
It's the sector preload spring. I've got a pdf showing the rebuild of a chevy steering column with excellent pics and explenation how to. Problem is I do not know how to post it on the forum. Maybe anyone can find it via google and posts it? The name I found it under is INSIDE THE GM TILT STEERING COLUMN by Jazzman. The spring is shown on page 22 and further.
04-01-2012, 05:49 PM | #5 |
Thank you guys so much. I fought it for a long time because my dimmer switch wasn't right but the ignition lock felt okay. Figured it must have something to do with the dimmer. But now I got it where it goes and hope to have it finished tonight or tomorrow - depending on if my wife will let me disappear again! Thank you again.
