Old 04-01-2012, 08:40 PM   #401
funkytechmonkey
funkytechmonkey's Avatar
Re: Project "Funky Monkey"
Originally Posted by 71Sleeper View Post
Did I read somewhere here that you got your tranny from Maddog?
yea that's where I got it from. they were good to deal with. and the owner is a really nice guy. my front seal is leaking a bit... I really hope they will cover that on the warranty.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 04-01-2012, 08:42 PM   #402
Rochlow
Looks great!
Rochlow is offline   Reply With Quote
Old 04-01-2012, 08:44 PM   #403
raull
raull's Avatar
buddy you are driving , thats awesome , im happy for you
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 04-01-2012, 08:59 PM   #404
ddubbs
ddubbs's Avatar
Originally Posted by funkytechmonkey View Post
took her out for a nice joy ride today. and man she handles good!!
I had tons of troubles the past few days, I post up some details tonight. just wanted to post up a semi_complete picture.
Just read your build thread. Man i have to congratulate you on a killer job. The truck looks absolutely Awesome. Keep up the great work.
ddubbs is offline   Reply With Quote
Old 04-01-2012, 09:16 PM   #405
zacthrasher
zacthrasher's Avatar
Hey I also just saw your thread, the truck looks great! Is it worth all the waiting and hard work when you finally get to start driving it?
My 67 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=473825
zacthrasher is offline   Reply With Quote
Old 04-01-2012, 09:29 PM   #406
funkytechmonkey
It really has been a ton of fun. I can't wait to get up enough cash to have it repainted and all the imperfections taken out of it. I'm a little disapointed in the borla exhaust. I think I bought the wrong ones. These are crazy loud and sound almost like glasspacks. Changing them out is my next task.
Old 04-01-2012, 09:38 PM   #407
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Not wasting any time. It's lookin' really nice!!
Alan's Classic is offline   Reply With Quote
Old 04-01-2012, 11:20 PM   #408
oldman3
oldman3's Avatar
Truck looks great, hope you work out all the little problems.....Jim
oldman3 is offline   Reply With Quote
Old 04-02-2012, 01:02 AM   #409
funkytechmonkey
So here is a breakdown of my build from day one.... The pros and cons of my build and what I have learned from my mistakes. Happy reading.
I bought the 71 GMC a little over a year ago with plans of just doing a frame off restomod with a static drop. I was looking for a nice 67-68 c10 and couldnt find one in the shape I wanted.... This was my first mistake. I had my heart on a 67-68 and that is what I should have bought. I knew some of you guys change the 69-72 to look like the 67-68 so I thought it would have been pretty easy. My 71 had leaf springs (another reason I should not have purchased it) and the body was in really bad shape. Parts of the body actually had chicken wire holding the bondo on. I have learned now how to look and check for these hidden flaws. After getting on this forum I found all of these great builds and vendors to help me get this thing started. I figured I would get rid of the leaf springs and go with the trailing arms, I started working with CPP and ordering parts from them but 3 weeks passed and they hadnt even processed my order. They ticked me off so then I was introduced to Porterbuilt. Porterbuilt was the absolute best thing that ever happened to my build. Nate is incredible to work with and they build some good stuff. Nate showed me the dropmember and how easy it was to intall bags and run a rack & Pinion so I was sold. After tearing down the 71 and parting out pretty much everything but the frame and the cab I was ready to start putting her back together. I realized the leaf spring mounts will not work with the trailing arms (No0b) so I had to get another rearend. I bought one from a forum member Chuck, got a posi and 373 gear for it, rebuild kit and new 5 lug axels, then opened up the axel and it was rusted out. No oil in it for years...So I had my powdercoat guy media blast the inside, and powdercoat the outside. I mocked up most of the suspension took it back apart and then sent it off to sand blast and powder coat. This is another thing I learned from. I really wish I would have thought it out a little more and built out the complete suspension with all the break lines, air lines, rack and all suspension components. Reasoning... I could have mounted the tabs for the ebreak on the trailing arm before powdercoat, I also could have made mounting brackets for the elevel system and made better mounting holes to run the hard lines to the bags. Then had it all powdercoated. I was able to manage with what I had... but It would have been easier. The only problems I ran into with my suspension was with my frame. For some reason my frame was 1/2" wider then a normal frame. No idea why.. Nate at porterbuilt sent me all new crossmembers and that fixed that problem. After getting the suspension back together I then installed the airride stuff mounting everything inside the frame and having it look perfect. Then one of my buddies told me I will end up melting the air hoses with the exhaust so we had to take all that out and install it in the rear of the truck. I couldnt find anyone that had soft lines local so i just went to summit and purchased the aluminum lines... now that was fun. I ruined a ton of line bending them. I am not as happy with the second install of the airride as I was with the first.
To be continued.... going to bed now.
Old 04-02-2012, 08:12 AM   #410
mcbassin
Still Learning
mcbassin's Avatar
You have done a great job on your build. What you describe above is "normal" from my point of view. I know because I did some of the same things. Unfortunately, that is how we learn. But just think about how much smarter we are now on the next one Keep your head up bro you're on the home stretch.
Old 04-02-2012, 10:33 AM   #411
Bennett68C10
Bennett68C10's Avatar
Truck looks awesome Brian, congrats on being finished atleat for now lol. If i was you, I would drive the heck out of it until winter time then maybe change some things if you want.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 04-04-2012, 10:22 PM   #412
suspect
suspect's Avatar
i just checked out your build from start. you sure did alot of work and parts quick. i'm impressed.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 04-05-2012, 10:39 AM   #413
funkytechmonkey
Well this afternoon the borlas are coming off and flowmaster 40s are going on. The borlas are the x2 series so, for me, they are too loud and have more of a glasspak sound to them. If anyone is interested in them I will have them up for sale on the classifieds tonight.
Old 04-05-2012, 10:56 AM   #414
truckmanloco
after looking at this pic I think I have decided to go with a bigger notch. that small cnotch doesn't go low enough.
Its looking great and i definantly agree with you on the bigger notch.
truckmanloco is offline   Reply With Quote
Old 04-05-2012, 10:07 PM   #415
funkytechmonkey
Another lesson learned and a big rookie mistake....double flare all brake lines. I had a bunch of leaks after I got the master cylinder mounted up. Most of them on the banjo bolts. We went back and tried to redo the flares with a double flare and I think we screwed a few of them up. Now my front tee is leaking perfusely. It was fine until today when I drove it on the rack of the muffler shop. I must have jarred it loose. Well... Looks like ill be redoing my front brake lines again.
that's brake fluid coming out of the tee running down my very clean and nicely painted frame. sucks!!
another reason I should have powdercoated the frame instead of painting it.
Old 04-05-2012, 10:21 PM   #416
lolife99
67-72 parts collector,…
lolife99's Avatar
Silicone brake fluid is better on painted surfaces.
Did you originally "double flare" your steel lines?
Keith
Convert to disc brakes.
Old 04-05-2012, 10:48 PM   #417
67cheby
67cheby
67cheby's Avatar
I hate learning lessons the hard way ! But it seems that is the only way I learn !!! Lol
67cheby is offline   Reply With Quote
Old 04-05-2012, 11:45 PM   #418
raull
raull's Avatar
this is what these toys do to you anyways , the want you to keep working on them !!!!
raul
Old 04-05-2012, 11:56 PM   #419
funkytechmonkey
I did not..... I had to go back and try to cut them back and then double flare them. I really hope I dont have to redo all my lines again.
Old 04-06-2012, 07:53 AM   #420
Mike Bradbury
Mike Bradbury's Avatar
Funny, I took off my F.M. 40's and put on glas packs because I thought the Flowmasters were too loud. Interested to hear how you like the swap
Mike
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 04-06-2012, 08:02 AM   #421
dnd1978
dnd1978's Avatar
HAHA!! Isn't that the truth.
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 04-06-2012, 10:45 AM   #422
funkytechmonkey
I dropped the truck off this morning to a local race shop called Balanced Performance. They are going to hook her up to a dyno and try to tune her a little bit. Hopefully that will fix my timing and power issues. I also talked to them about the brake lines. They make brake lines for these race cars so they should be able to fix what I screwed up. Hopefully there will not be any problems there.
Old 04-07-2012, 08:46 PM   #423
eldogg
eldogg's Avatar
WOW Son!! I haven't looked at your thread lately, You have been working your tail off on that thing and it looks great! Talk to you soon....
eldogg is offline   Reply With Quote
Old 04-08-2012, 09:37 AM   #424
funkytechmonkey
Eric I may need to ride up to your shop and talk to you about this motor. We put it on the dyno at Balanced Performance on Friday and I didn't get the numbers I was looking for. We got it tuned up pretty good but its still very slugish. We got it to about 240 hp and 325 fp and then started messing with the timing now I'm around 218 hp. It's that crate 355 that I put a TBI on, aluminum heads, roller rockers, and hardened pushrods. When I try to get on it I feel like its really struggling to go.
Old 04-11-2012, 09:02 AM   #425
eldogg
eldogg's Avatar
No problem. Just let me know.
