Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-02-2012, 09:26 AM   #101
scotts62
One day...
scotts62's Avatar
Re: Our "What are we going to do?" 66 Suburban Build
Hey looking good!!
Scott
93 crew cab build
Project 62
Old 04-02-2012, 01:32 PM   #102
oem4me
Originally Posted by RockTonka View Post
We just couldn't leave well enough alone and had to pick up some 275/60R15's to try on for size...we like the look alot more. We'll probably pick up some 255/60R15s for the front to finish it off...check the classified section for the new tires and stock wheels/hubcaps that are coming off
Was loving the stock set-up myself, but glad you found something you like better. I would be interested in that set if you sell, but pretty sure shipping would kill any deal.
Old 04-02-2012, 06:16 PM   #103
RockTonka
RockTonka's Avatar
Originally Posted by scotts62 View Post
Hey looking good!!
Thanks Scott, appreciate that.
Maybe not, I can get pretty attractive shipping rates...PM sent oem.
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is online now   Reply With Quote
Old 04-02-2012, 06:29 PM   #104
RockTonka
RockTonka's Avatar
new page needs a new pic to kick it off (one my son took)...
My build thread
Old 04-08-2012, 09:19 PM   #105
RockTonka
RockTonka's Avatar
Had a local young striper lay down a bit of work on the burb...
My build thread
Old 04-09-2012, 02:08 AM   #106
C@rnut001
That looks really good. Awesome addition to this cool burb!
C@rnut001 is offline   Reply With Quote
Old 04-10-2012, 09:08 PM   #107
RockTonka
RockTonka's Avatar
Thanks carnut, it's fun to tinker around with different flavors on this burb. At some point we want to repaint it, but for the time being...
My build thread
Old 04-22-2012, 01:33 AM   #108
RockTonka
RockTonka's Avatar
Originally Posted by Captainfab View Post
Yep, I do like those tires and wheels better....of course I'm a little partial, since that is what I run on my Burb. I had 255's on the front for a while, but IMO they were a little too small. So now I have 275's all the way around.
Man I miss driving my Burb......hopefully soon.
Well Capt., you made us rethink our tire size decision and after a bit of pondering, we decided to follow your lead and go with 275/60R 15s all the way around. Glad we did, we like the look!
My build thread
Old 04-22-2012, 01:39 AM   #109
RockTonka
RockTonka's Avatar
These ralley's were originally from a 4x blazer and the front center caps were open...my son came up with this short-term solution
My build thread
Old 04-22-2012, 03:03 AM   #110
RockTonka
RockTonka's Avatar
We're thinking about selling all the seats out of this and going a different direction
Check out the WIW section and help us make a decision...thanks!
My build thread
Old 04-22-2012, 06:43 PM   #111
justcuz
justcuz's Avatar
Since you are not staying stock and you want to lower it a little, I would suggest taking the coil overload shocks out of the back and see where it settles. Then pull the front coils and cut 1/2 to 1 coil out of the front springs. This should settle the rear up to an inch and you can lower the front 1.5 to 2 inches with coil cutting. I use Vise Grips next to the cut and a wet rag inside the Vise Grips as a heat sink and cut the coil with a Skil saw with a metal cutting blade. That way you don't damage the spring tension buy using a torch. Since you are not staying stock I would put a set of disc brakes up front. 3.73's with the 700R4 in OD is a 2.62 highway gear. That engine will not be turning many rpms. A rebuilt 350 with a 305 HO cam, an HEI with a curve kit and a quadrajet, would be a nice engine for that truck if you want it to be a cruiser. A set of nice gas shocks on it and add a front sway bar with urethane bushings, it will ride and handle like a dream. What I love about these old trucks is the A arm bushings are lubable and last forever, not like the later rubber ones that wear out.
justcuz is offline   Reply With Quote
Old 04-22-2012, 07:30 PM   #112
RockTonka
RockTonka's Avatar
Hey man, get out of my head!
You're almost spot on with what we've been thinking!...almost.
Talked to CPP Friday about their Grand Slam kit and adding front/rear sway bars, dropping the front 2.5" with spindles and bringing the rear down just enough to leave us with a bit of rake. The rear is sitting low (even with the overload shocks) because of the really tired stock springs...we're gonna have to do some fiquring to decide which front/rear springs to go with and get the stance right.
Now, as far as the engine goes...
I've got a nice little 468 being built down in Houston that will be pushing 500 hp on pump gas...will be picking it up mid-May
My build thread
Old 04-22-2012, 10:53 PM   #113
justcuz
justcuz's Avatar
Cool, just make sure the springs are strong enough in the rear to handle the family and your picnic basket for cruises and car shows. I've seen guys put different weaker springs in the rear and have it banging off the bump stops with a couple rear seat passengers. For me I have to keep it limited to modifying stock suspension at most. My wife says I have dirt road fever and when we travel we hardly ever take one of the cars any more. I always want to know whats down that dirt road. I guess you can take the boy out of the country, but not the country out of the boy. I was born in Northwest Ohio and when I go back it still feels like home to me. 15 minutes out of any decent sized city in Northwest Ohio and your out in the country, I love that!
Old 04-23-2012, 01:15 AM   #114
Captainfab
60-66 Nut
Yep those tires look good.
When choosing your front springs and spindles, just remember that big block is going to drop the front a little more.
Old 04-23-2012, 01:27 AM   #115
RockTonka
RockTonka's Avatar
One of the reasons I'm talking with CPP is their "heavy-duty" rear springs...I'd actually like to increase the rear spring rate for exactly the reasons you've stated.
My build thread
Old 04-23-2012, 01:33 AM   #116
RockTonka
RockTonka's Avatar
Planning on it...
My build thread
Old 06-06-2012, 04:27 AM   #117
MikeS.
MikeS.'s Avatar
No updated for 6 weeks, what's up??
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 06-07-2012, 09:53 PM   #118
RockTonka
RockTonka's Avatar
Just been enjoying it while we gather up parts. We picked up a mildly built long block BBC and have been dressing it out...just finished the alt mount, working on the ps and ac compressor mounts next. We also swapped out the 700R4 for a built 400...should handle the BBC better.
My build thread
Old 06-08-2012, 01:38 AM   #119
Dinos63
chevy only
Dinos63's Avatar
oh boy!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 06-08-2012, 05:11 PM   #120
scotts62
One day...
scotts62's Avatar
Scott
93 crew cab build
Project 62
Old 06-09-2012, 11:33 AM   #121
thirdstreettito
Resident of Here
thirdstreettito's Avatar
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 06-10-2012, 01:45 AM   #122
jbclassix
Junk Yartist
jbclassix's Avatar
big block everything huh?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 06-10-2012, 06:46 PM   #123
RockTonka
RockTonka's Avatar
Originally Posted by Dinos63 View Post
oh boy!
Originally Posted by thirdstreettito View Post
Oh yea, "no replacement for displacement" holds true around this household!
I just dig big blocks, always have, always will!
This one is running forged 10:1 domes in a gen VI block w/ 049 heads, bit of a lumpy cam and a Holley 750 on a air gap.
Not alot more done this weekend, but did get the ps mount pretty much done...just got to drop a tensioner on it.
Just keep chipping away at it...
My build thread
Old 06-11-2012, 12:09 AM   #124
abebummy26
abebummy26's Avatar
I've loved subs ever since before I could say it called them Burbans when I was about 3 or four. This one makes me love them even more. Super nice rig hope you guys really enjoy that thing.
-Lincoln
1987 GMC S15 (soon to be a chevy clone)
2.5l, 4 speed, no ps, no pb, no ac
Silence is golden, but duct tape is silver.
Spoken by Cletus the hillbilly
I like stickers... a whole bunch.
abebummy26 is offline   Reply With Quote
Old 06-12-2012, 02:49 PM   #125
piratexpress1369a
piratexpress1369a's Avatar
that is cool shot with the sun going down
piratexpress1369a is offline   Reply With Quote
