So,, what else you got???
![]() Join Date: May 2010
Edelbrock SP2P aluminum intake manifold for small block Chevy w/oil fill hole.
We came across this intake in our sorting around the shop. Edelbrock aluminum intake for small block with the oil fill hole. Model is SP2P and it is for pre 86 cylinder heads. These were low rpm torque curve intakes and are not recommended for big inch, high horsepower engines. Great replacement for that old cast iron manifold. $80.00 shipped. Thanks, Fred
Re: Edelbrock SP2P aluminum intake manifold for small block Chevy w/oil fill hole.
Forgot to mention,, have the fill tube as well.
Pic of oil fill tube
Posted via Mobile Device |
Will try to get it for you tonight if we can. Thanks
![]() ![]() Join Date: Dec 1999
I have had a couple of these intakes.
Great replacement for a stock engine, or one with a just over stock cam. Performance is a lot better taking off. And better mileage as well(for me,stock engines). Any buyer considering this who doesn't need the oil fill tube can use a rubber expansion (frost plug)plug for the hole.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
![]() Join Date: Aug 2011
will it work on a 400 SB? If so I will take it for $80.00 shipped to 72019
Thanks Joe Hester |
Hey Joe. Yes, will work on your 400 as long as you don't have late model (after 1986) cylinder heads. Paypal is sharley@cablerocket.com Thanks, Fred.
Great! Motor is 1977 with original heads so should be good.
PM sent
Thanks Joe Hester |
Finally....Paypal sent!
Thanks Joe Hester |
Hey Joe, will send it out Tuesday morning.
