Re: another brake pedal question
no expert but if your pedal is stiff (motor off) and then soft.
THe stiffness is most likely the resistance with the brake booster and then with engine vacuum the booster assists. (working correctly). if your pedal is soft while engine running, you must have air in the lines or rear brakes need adjusting??? start with the bleeding, chris |
| Bookmarks |
| Tags |
| brakes, master cylinder, new pads, soft pedal |
