Closed Thread
Old 04-02-2012, 09:15 AM   #3776
dmwphoto
dmwphoto's Avatar
Re: What did you do to your truck today!
Originally Posted by aventur1 View Post
Got up this morning at 2:45 this morning because my horn was blarring! My horn just started blarring on it's own, mmmmm wonder what caused that?
your truck was lonely.....
Temp change and horn contact problem
dmwphoto is offline
Old 04-02-2012, 11:26 PM   #3777
aventur1
aventur1's Avatar
Found out why more horn was blowing last night, horn button popped off....found it on the seat this morning...
1968 4x4 Frame, with a 67 Cab and Bed
A Shorter Step
1999 Dodge 2500 Cummins Diesel
aventur1 is offline
Old 04-03-2012, 01:48 AM   #3778
dukcaln
dukcaln's Avatar
finally replaced the dash bulbs today....boy what a difference at night now....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline
Old 04-03-2012, 10:20 AM   #3779
Bert W
Bert W's Avatar
I haven't done much, still taking parts off as opposed to putting them on. So I took pics. My plan is to pressure wash it this weekend.
1968 Chevy C/10 LWB V8
1983 K5 Blazer
1989 C1500 Stepside Reg. Cab V8
Bert W is offline
Old 04-03-2012, 10:30 AM   #3780
Shyguy
Junior Member
Shyguy's Avatar
I went out to the garage and looked at the rust damage on my '67 cab which is located under the cowl and just shook my head and left confused. This is nothing unusual for me since this is the first truck I have tried to fix with so much rust.
Decided what the heck, might as well go to my son's house and see how he was doing on restoring the '68 GMC swb fleet and to have the evening meal with them.
When I got there he was just getting back from test driving the truck, it was not running right so I watched him adjust the carb.
After eating we decided what the heck, might as well put the hood on since it was the last piece of the sheetmetal to go on after painting. I had never adjusted one myself so I learned it takes time, patience and a lot of adjusting if you have taken a truck all the way apart and painted each piece individually.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 04-03-2012, 10:38 AM   #3781
Shyguy
Junior Member
Shyguy's Avatar
My truck is taken apart about as yours, but mine had a lot more rust problem than yours.
Most people probably would have just got another cab, but since I wanted to learn how to repair rust we cut out rust and put on at least 12 repair pieces.
I am lucky because my frame was cleaned by a PO who never finished the build. All I have to clean up is the front cradle and firewall.
Shyguy is offline
Old 04-03-2012, 12:25 PM   #3782
dukcaln
dukcaln's Avatar
finally got the 5" tach installed
SOLD 1972 chevy c10
dukcaln is offline
Old 04-03-2012, 04:55 PM   #3783
bbadfred
bbadfred
bbadfred's Avatar
I am a day late but yesterday I DROVE mine for the first time since 2000!!!!! Today worked on the kick panels and speaker wiring
bbadfred is offline
Old 04-03-2012, 11:56 PM   #3784
Shyguy
Junior Member
Shyguy's Avatar
Here is a few pictures of the '67 swb GMC I helped my son put the hood on yesterday.
My son is in the background of one of the pictures taking a picture with his cell phone.
Shyguy is offline
Old 04-05-2012, 08:20 AM   #3785
wrwelton
wrwelton's Avatar
Well its time to work on the grill. I removed the center and coated it with oven cleaner. Wow that stuff works great. I have sanded it down with 600 grit where scratches were bad and now I am sanding it with 800 grit, wet sanding the whole way. I think I will go with 1000 grit and see how it looks. I am putting the windshield and slider in this weekend. Should be stasrring the truck next week.
I know I can! I know i can! 72 K20 Restoration
wrwelton is offline
Old 04-05-2012, 08:35 AM   #3786
aventur1
aventur1's Avatar
Guess I did not know you could sand the grill to shine like that by wet sanding using 800 to 1000 sand paper....looks nice good job.
A Shorter Step
aventur1 is offline
Old 04-05-2012, 06:18 PM   #3787
wrwelton
wrwelton's Avatar
It still needs to be buffed. I painted around headlights today and working on plastic grill. Anyone know if I should paint leading edge of plastic grill.
wrwelton is offline
Old 04-05-2012, 08:43 PM   #3788
redmonster
redmonster's Avatar
upper and lower radiator hoses, replace radiator, water pump,thermostat, wire harness from fuse block
trying to get the temp gauge to work
picked this up monday
WITNESS
Dont be like me be better than me
redmonster is offline
Old 04-05-2012, 08:47 PM   #3789
redmonster
redmonster's Avatar
67-68 original chevy blue steering wheel
WITNESS
Old 04-05-2012, 10:16 PM   #3790
bollybib
bollybib's Avatar
The driver side lock mechanism was stuck so I lubed everything and found a broken spring in the door handle. The lock & handle work fine now even with the busted spring.
Next up is a headlight warning buzzer (NAPA 7821637).
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline
Old 04-05-2012, 11:58 PM   #3791
jayman68
Fun Stuff
jayman68's Avatar
Congrats, must feel good!
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline
Old 04-06-2012, 09:13 PM   #3792
ffk
ffk's Avatar
installed new front 2 1/2 drop spindles , zinc coated drilled and slotted rotors,new ball joints,tie rod ends,pitman arm , ect.new motor mounts and trans cross member
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604)
ffk is offline
Old 04-06-2012, 11:07 PM   #3793
67cheby
67cheby
67cheby's Avatar
Nice
67cheby is offline
Old 04-07-2012, 12:55 AM   #3794
PAWS 72
PAWS 72's Avatar
Cleaned her up good for the first show of the year.I'll take some pics of what is there and post them.
Where do you post pics of the shows? Here or somewhere else?
PAWS 72 is offline
Old 04-07-2012, 08:03 AM   #3795
cpisani70@aol.com
cpisani70@aol.com's Avatar
Decided it was time to tackle some tranny leaks! I have been working on these trucks for years but transmissions are one place I'm very weak at , that said I'm very happy with the result. The truck is a 71 C-20 402/400 , leak at the modulator so I pulled it and when I called the local parts store they had one in stock and it was $6 so that was a no brainer! Next came the speedo assembly, I managed to remove it without breaking anything, brought the whole thing to a tranny shop where they put all new seals in it right there and charged me $10, so both leaks were repaired the same day for under $30 without breaking anything! I know this is long winded but seldom do things go this smooth.
cpisani70@aol.com is offline
Old 04-07-2012, 09:44 AM   #3796
longbed67
longbed67's Avatar
Wasnt today... but Thursday night I dropped in the motor and trans!
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline
Old 04-07-2012, 10:12 AM   #3797
88fordf150
88fordf150's Avatar
Wow! Looks like thats going to be one hot little 6.
Brad handshoe
88fordf150 is offline
Old 04-07-2012, 11:07 AM   #3798
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
yesterday I completed 90% of the new efi fuel system. I had to add a return and make some fitting/end changes, which ultimately wound up in my removing all the 1/2" aluminum tube and -8 AN fittings and s.s. hose...and replacing with -6 AN s.s. hose and fittings.
today..finish the fuel system, install a few sensors...and on to wiring!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline
Old 04-07-2012, 11:25 AM   #3799
dukcaln
dukcaln's Avatar
found a plug wire resting on the header...... nice burnt wire so I replaced with a longer set that can actually route better..... running pretty good so wonder how long that was going on!!!!!!!!!!!!!
SOLD 1972 chevy c10
dukcaln is offline
Old 04-07-2012, 11:28 AM   #3800
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Finished testing my modified speedometer.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline
Closed Thread
