Old 04-01-2012, 02:19 PM   #226
noonzor
Re: 69 c10 -- first project!!
i came up with 7.250" which sounded short to me but i dbl checked and thats the measurment i got. i tried a cpl stock pushrods i had laying around and 7.4" is too long, the wipe was clearing edge to edge.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 04-01-2012, 03:16 PM   #227
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
I wasn't thinking about the new rockers
that could be it...with the rocker change needing something different. I didn't notice but what lifters are you running? I think the LS7 style lifters lash is more like .080-.090 vs .050-.060 for GenIII/early GenIV?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-01-2012, 03:47 PM   #228
noonzor
Lifters are comp
Old 04-02-2012, 01:58 PM   #229
noonzor
so did some research, some fitting and testing and checking... now my head hurts, but i got it all figured out. its simply the fitment of the rockers. heads are coming off and getting dissasmbled so i can clean them up and going to do a quick polish job while ive got them apart. ive got to wait for some new assembly rags to come in so itll be a cpl weeks before i get down to it. in the mean time im going to clean the block back up, as its gotten quite dirty since i primed it, and finish the paint job. im not sure i like the stock valve covers and am seriously contemplating buying some nice fab'd ones. opinions?
Old 04-03-2012, 02:35 AM   #230
smoknbarrels
Registered Mail
smoknbarrels's Avatar
Just did the full read through.. looking awesome! so what kinda hp numbers are you looking at with the hair dryer installed? are you gonna go for a 1 piece drive shaft?
aired out that truck is gonna have a wicked slant with that Frnt Dropmember... actually I shouldn't assume everyone uses bags when using Dropmembers, what are your suspension ideas?
smoknbarrels is offline   Reply With Quote
Old 04-03-2012, 10:31 AM   #231
noonzor
Thanks man. Its gonna be a static drop, 4 corner coilovers, have to figure the ride height still. With the twins installed im shootin for 800hp. One piece driveshaft for sure, trailing arms, anti-roll and panhard bar. Ill be redoing the cnotch soon here, just need to get the truck into my new garage and i can start working again. Hopefully another month and ill move her in.
Old 04-03-2012, 11:04 AM   #232
smoknbarrels
Registered Mail
I was originally going to go with a full coil-over set-up also.. what is wrong with the CPP notch you already have in? it looked done well, thinking of a bigger one?
well if you stick with the CPP, I've got a free part for you if you want it.. it's a Competition Engineering rear coil-over kit. it's only like a $150 kit (or something) I welded it all up, built it to work with a CPP cnotch, basically it bolts flush into the rear two bolt holes of the notch, the bar sits on top of the frame rails, but still clears the bed. this is the widest setup you can go without mounting coilovers outside the frame rails and sacraficing tire width.
I will never be using it as I won't be going coil-over, so you can have it if you want.
Name:  may 001 (Small).jpg
Name:  may 002 (Small).jpg
Old 04-03-2012, 11:15 AM   #233
noonzor
sweet thanks for the offer dude. i took a look through your build there and saw it, nice work so far! where abouts in alberta are ya?
im going to redo the notch so i can weld everything in for more strength. the cpp notch is a nice piece but its just not for what i want to do with the truck. the rear set-up im going for is similar to how djracers 67 is set up, same idea with a different touch.
Old 04-03-2012, 12:31 PM   #234
smoknbarrels
Registered Mail
I am about 30 mins from edmonton. I've looked at DJ's set-up a few years back on the form, it works really well for him. are you going for street legal? that truck of yours will end up being crazy fast! congrats on the engagement, our big day is in Feb.2013.
Old 04-29-2012, 08:03 PM   #235
noonzor
truck will be street legal but built for 1/4 mile racing. im sure hoping shes fast with the time and money that will end up in her!! lol.
small update, heads are clearenced for the rockers, everything is back installed, painted and clear coated, balancer installed and then all plastic wrapped for storage till i can finish it off. the house vacuum died the other day so the fiance and i went shopping for a new one. holy sheet batman, i could buy another project car for cheaper then these damn dirt suckers now adays!! well we both agreed to make this vacuum the last one we'd buy for a long while and we went all out on it. so im broke for a while again now haha. good news is little bro's camaro is almost back together and will be leaving the garage very soon. so id say end of may my truck will be sitting in her new home till she drives out!
pics to follow.
Old 05-19-2012, 08:22 AM   #236
noonzor
pics i promised..... Just need to install my balancer/timing cover seal and then im waiting to talk to edelbrock about the proflo xt intake which is what im looking at getting. The motor should be on a dyno by mid june.
Old 05-19-2012, 09:48 AM   #237
67cheby
67cheby
67cheby's Avatar
WOW...is that the color the truck will be ?
67cheby is offline   Reply With Quote
Old 05-19-2012, 09:59 AM   #238
noonzor
Haha naw man. The truck will be green, the drivetrain will be purple.
Old 06-15-2012, 06:24 PM   #239
noonzor
LOOK WHAT CAME TODAY!!! (besides me upon opening the box)
dayumn, this thing looks WAY better in person then photos have ever shown.
Old 06-15-2012, 06:58 PM   #240
tubbedII
needs more $$$
tubbedII's Avatar
HAHAHAHA! That thing sure does look awesome!!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 06-16-2012, 11:31 AM   #241
PHAT TONY
PHAT TONY's Avatar
Shawiinngg! Good to see you keep your liquids up while slavin away in the shop; attaboy!
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 06-16-2012, 11:43 AM   #242
67cheby
67cheby
67cheby's Avatar
that intake is AWESOME !
Old 06-16-2012, 05:21 PM   #243
noonzor
thanks cheby, i really like it. i was going to hold out for the holley hi-ram, but i REALLY like this edelbrock now that its in my hands. cant believe how huge it is.
quick suggestion poll.... for those of you who arent fans of the purple already disregard haha. should i leave the rails black or purple em up? yay/nay?
Old 06-16-2012, 10:38 PM   #244
67cheby
67cheby
67cheby's Avatar
Black use the purple as an accent color
Old 06-20-2012, 03:49 PM   #245
noonzor
just ordered my injectors.
http://fuelinjectorconnection.com/sh...p?productid=21
talked with jon at the shop there, incredibly nice guy and had all the answers i needed. ill be going on holidays soon here but am hoping to have the motor on the dyno in august, numbers and turbo selection to come!
Old 06-20-2012, 04:21 PM   #246
mcbassin
Still Learning
mcbassin's Avatar
Very cool project! You and I started our projects around the same time in 2009. Looking forward to following it. Subscribed.
Old 06-21-2012, 12:07 PM   #247
noonzor
i agree. black rails, black balancer, black pulleys. itll be sweet.
thnx dude, ive been following your build aswell i really like it!
Originally Posted by MJs69CST View Post
Motor looks awesome!
thanks man!
Old 07-06-2012, 01:07 PM   #248
noonzor
GOOD NEWS!!! little bro finally got his camaro out of my garage, so im just going through cleaning and re-organizing then ill have my truck home very soon!!! called and ordered my new boyd tank today!! BOOYAH super stoked to get it! the motor is almost ready to hit the dyno, just waiting on a cpl items and its ready to run!!!
Old 07-08-2012, 10:14 PM   #249
67c10rustbuket
67c10rustbuket's Avatar
Holy cow that intake is awesome looking!!!
My daughter would love the purple engine, that's her favorite color. It is different for sure, I Painted one lime green before .
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 07-08-2012, 10:34 PM   #250
noonzor
yeah my neighbors daughter loves it too haha. the colors will all make sense in good time. the truck has a theme, what that theme is will be revealed closer to completion.
