Old 04-03-2012, 10:43 PM   #1
1965zac
Floor Shifter
I am getting ready to put a floor shifter in my 1965 c10 but I don't know how tall I want it.
Does anybody have any pictures of theirs? I am thinking 23-30" range.
1965zac is offline   Reply With Quote
Old 04-03-2012, 11:15 PM   #2
creep
Registered Loser
creep's Avatar
Re: Floor Shifter
I put a B&M Unimatic in mine.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 04-03-2012, 11:27 PM   #3
jocko
jocko's Avatar
Re: Floor Shifter
If buying an aftermarket, I recommend the 16"-ish ones. You can see the pics and the part numebrs of mine if it is what you're looking for. 16-16.5" is about the tallest I've seen without going to the Count Dragula rat rod sticks that scrape the roof. Anyway, this thread has more than you're looking for - but it does have the stick info and pictures for reference/comparison to help you decide. Hope it helps. http://67-72chevytrucks.com/vboard/s...d.php?t=482069
EDIT: Oops - just noticed it sounds like you want a tall!!! one, anyway - maybe the pics here will give you an idea how much taller to look for.
Old 04-03-2012, 11:31 PM   #4
A.T. RockDriller
A.T. RockDriller's Avatar
Re: Floor Shifter
What's goin on with that intake manifold that I think I'm seein in yer first pic there, creep....?
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-04-2012, 01:05 AM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Floor Shifter
What transmission are you running?
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-04-2012, 01:06 AM   #6
doobiebro
doobiebro's Avatar
Re: Floor Shifter
Old pic...23 inch Gennie shifter...interior finished with bench seat and it looks nicer. will need to post pics later..
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline   Reply With Quote
Old 04-04-2012, 07:48 AM   #7
creep
Registered Loser
creep's Avatar
Re: Floor Shifter
That's a scoop.
Old 04-04-2012, 03:37 PM   #8
66GTO66C10
66GTO66C10's Avatar
Re: Floor Shifter
16" Lokar shifter
1966 Chevy C10 frame off resto (In progress)
1966 GTO Numbers matching original
1989 Toyota Pickup (Tonka) resto
2002 HD FLSTC
2000 HD FLSTC
1996 Ninja ZX11
Believe nothing of what you hear, and 1/2 of what you see!
66GTO66C10 is offline   Reply With Quote
Old 04-04-2012, 07:04 PM   #9
gimmy 64
Re: Floor Shifter
23 inch lokar on low hump
gimmy 64 is offline   Reply With Quote
Old 04-04-2012, 08:41 PM   #10
1965zac
Re: Floor Shifter
Old 04-04-2012, 08:42 PM   #11
1965zac
Re: Floor Shifter
I'm running a 700r4. Gimmy I really like the looks of yours. Looks great!
Old 04-04-2012, 11:20 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Floor Shifter
Here’s what mine looked like many years ago when it had a TH350. Both shifters came through the original SM420 hole in the floor pan after about ¼” of trimming:
The first 3 are a 23” Lokar with a high hump floor:
This is after I swapped in a 16” Gennie Shifter:
Old 04-04-2012, 11:39 PM   #13
doobiebro
doobiebro's Avatar
Re: Floor Shifter
gimmy I been looking for a steering wheel like yours...I always liked the old skool grant looking steering wheels....who makes it and where did you find yours? Did you have to install a steering wheel adapter for that steering column you have? Im in the process of installing a hot rod universal GM tilt steering column with a 9 bolt steering wheel adapter on my truck..cant believe the steering wheels cost just as much as what I payed for the steering column..
Old 04-05-2012, 01:16 PM   #14
gimmy 64
Re: Floor Shifter
this is from mooneyes they come in like 5 differant colors and are cheep around 70bucks. yes you need an adapter fot this wheel. moon sells them too about 20 bucks
Old 04-05-2012, 05:23 PM   #15
doobiebro
doobiebro's Avatar
Re: Floor Shifter
gimmy thanks for the info...
