Old 04-04-2012, 04:58 PM   #1
rynophiliac
rynophiliac's Avatar
crinkle in weatherstripping
I just put in some brand new weatherstripping but it is crinkled in the corners? I there anyway to fix the crinkles? Should I cut the weatherstrip into two sections?
rynophiliac is offline   Reply With Quote
Old 04-04-2012, 05:08 PM   #2
orangek5
orangek5's Avatar
Re: crinkle in weatherstripping
Won't the seal plate Name:  8e516a796b948b0cf8bc6d992d7a.jpg
Size:  6.9 KBcover that?
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 04-04-2012, 05:37 PM   #3
rynophiliac
Originally Posted by orangek5 View Post
Won't the seal plate Attachment 902805cover that?
I am not sure, my blazer did not come with seal plates, but they are on my list of things to buy. Do the seal plates go into the corner and up the side of the door a little bit? I have crinkles in both lower corners.
Old 04-04-2012, 07:41 PM   #4
Firebirdjones
Yes your door sill plates should cover that.
See the body joint where your lower rockers are spot welded??
My door sill plates almost reach up to that joint on both sides of the door, so it should more than cover your weatherstrip wrinkles.
Firebirdjones is offline   Reply With Quote
