Old 04-05-2012, 10:05 AM   #1
Breadstick
Newbie needs help removing drum on 64 C10
I have never really worked on drum brakes before but I'm pretty sure my front pads are shot. I am trying to get the drum off so I can check them but I can't get it to come off. I have read a lot of threads but I can't seem to find anything that says how to get it off. It moves freely but I can't get it off the hub. Please help me.
Breadstick is offline   Reply With Quote
Old 04-05-2012, 10:11 AM   #2
1963c-10
1963c-10's Avatar
Re: Newbie needs help removing drum on 64 C10
You might have to pull the hub with it. Some of the drums were pressed on. Remove the dust cap, the cotter pin & nut and the drum assembly should come off.
1964 Short bed trailer
Old 04-05-2012, 10:15 AM   #3
Breadstick
I tried that and it didn't work. Should I be able to get to the nut and cotter pin with the drum on? It looks like the previous owner welded a small section of pipe on top of the cotter pin and bolt.
Old 04-05-2012, 10:19 AM   #4
1963c-10
1963c-10's Avatar
Yes. Once the wheel is removed, you are looking at the drum. The center dust cap needs to be removed and then you should have access to the cotter pin and nut. Can you provide a pick of the the weld work the previous owner did?
Old 04-05-2012, 10:30 AM   #5
Breadstick
The first picture is with the dust cap on. The second is with it off. It's hard to tell the distance, but I can't get the cotter pin out to get the nut off. I'm out of ideas now.
Old 04-05-2012, 10:47 AM   #6
SHutt24
Make sure you remove that bearing buddy and you should be able to access the cotter pin.
SHutt24 is offline   Reply With Quote
Old 04-05-2012, 10:47 AM   #7
1963c-10
1963c-10's Avatar
Im guessing its a 4x4 with the hub sticking out like that?
Old 04-05-2012, 10:50 AM   #8
Breadstick
It's not a 4x4. What bearing do I need to remove? I can see the cotter pin in the cylinder sticking out of the drum but there is no way to get the cotter pin out, or do anything with it the way it's setup.
Also, will I need a special socket to get this nut off?
Old 04-05-2012, 10:52 AM   #9
1963c-10
1963c-10's Avatar
It looks to me that the snap ring will need to come off the bearing buddy to remove it. Those I am not familiar with, but SHutt24 seems to know what it is. You will not need a special socket to remove the nut. It also appears that the drums have been rivited on. But by pulling the hub assembly, the drum will come off. If it is pressed or rivited on, I have it pressed off once removed.
Old 04-05-2012, 10:52 AM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Umm... I have never seen anyone use a Bearing Buddy on anything other than a trailer hub. Very interesting... in a weird way.
Looks like you still have the stock rivets holding the drum to the hub. From what I know, you end up grinding off the heads and using a punch to pop them out. Then you can get the drum off the hub, have it turned/replaced and do your brake work.
As for the hub, I am not even sure how you would get a cotter pin in that, let alone get it out.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-05-2012, 10:57 AM   #11
FreakyMalo
FreakyMalo's Avatar
That section with the blue sticker needs to come off. It's an aftermarket bearing greaser. Is it welded? Try tapping the sides of it back and forth with a hammer and see if it'll wiggle off. Or grab the end with some channel-locks/vise-grips etc. Then find some stock dust caps.
66 Carryall
my photos
FreakyMalo is offline   Reply With Quote
Old 04-05-2012, 11:10 AM   #12
SHutt24
If that bearing buddy is welded to the hub the welds will need to be ground off and you should able to just knock it off. Never seen a bearing buddy on a truck hub before, usually only installed on a trailer like chevy_mike said.
Old 04-05-2012, 11:23 AM   #13
Breadstick
Found the dust cap. O'reilly can order it and have it tomorrow, so the saga will continue. The OEM one is on the passenger side, but it's pretty beat up. It might be a bit of a bear to get off.
Old 04-05-2012, 11:40 AM   #14
61K10
61K10's Avatar
go to a good auto parts store like napa, and find the help section. should be some caps there. take the bearing buddy with you for the right fit. also a wrecking yard. good luck
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-05-2012, 12:00 PM   #15
markeb01
Senior Enthusiast
markeb01's Avatar
Here's an image of the Buddy Bearing to clarify what needs to be removed:
Interesting I'd never heard of one of these before reading this post.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-05-2012, 12:35 PM   #16
Breadstick
Thanks for all the replies and good information. My wheel bearing dust caps will be at the parts store tomorrow morning. I'll take the buddy cap off then and finally take a look at my pads.
Old 04-05-2012, 12:41 PM   #17
cori 64
cori 64's Avatar
it looks to me that the rivets still need to come off!!! grind them off then that will be one problem down!!if they still dont come off bust out the cut off wheel!!!slice the whole drum in half!!if you cant get to the adjusters!!!
cori 64 is offline   Reply With Quote
Old 04-05-2012, 02:30 PM   #18
Slow Build
Slow Build's Avatar
I use a big rubber mallet and hit it hard. It's not like your going to use it again.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-05-2012, 07:00 PM   #19
A.T. RockDriller
A.T. RockDriller's Avatar
Take yer C-4 and kinda shape it into a cone...about 3" at the.......
Oh....
Nuthin.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-05-2012, 08:54 PM   #20
jocko
jocko's Avatar
now that's a sure fire approach! I'm with slow build, whack it with a big honkin hammer. Can someone tell me what the heck a buddy bearing is and why it exists?
Old 04-06-2012, 12:29 AM   #21
A.T. RockDriller
It's a pretty cool invention, actually...
For the most part...the best application for them is a boat trailer.
Guys that launch their boats off their trailer use them just cause it is a spring loaded thingy that ya pump up with yer grease gun....and then it keeps a constant pressurised flow of grease into the brg & hub assy.....Kinda keeps you off the side of the freeway with a wheel bearing failure when yer on your way to or from your favorite fishin' hole.
Les Hunter
Old 04-06-2012, 03:42 PM   #22
jrisch
jrisch's Avatar
Grind the rivits down and it should come apart without taking the hub off!!
1962 Chevrolet S/B Fleet side
Engine: 283 Transmission: 3 speed manual
2 do list !!!!!!
Frame off-2 1/2" front , 4" rear
Rebuild engine (or find a 327), 700R4 Trans, relocate gas tank, Bed wood
jrisch is offline   Reply With Quote
Old 04-06-2012, 04:49 PM   #23
Breadstick
I knocked off the Bearing Buddy with one decent hit and it came apart perfectly once I got the cotter pin and nut off. My shoes are good and the adjusters aren't too close together, so I guess it's time to bleed the master cylinder. My brakes work, just WAAAAAY too much pedal travel to make the truck stop.
Old 04-06-2012, 05:03 PM   #24
markeb01
Senior Enthusiast
markeb01's Avatar
Unless you have air in the lines, the excessive pedal travel is probably indicating the brake shoes need to be adjusted. If the shoes are too far away from the drums it can take a great deal of pedal to take up the slack. I always ran the star adjusters up to the point they wouldn't turn anymore, which also locks the brake and centers the shoes in the drum. Count the clicks required to back them off to the point where they just barely touch the drums (while spinning the drums). Then repeat the process on the opposite drum, backing off the shoes on the other side the same amount of clicks. This way they won't pull to one side or the other.
Old 04-06-2012, 06:09 PM   #25
chevy_mike
chevy_mike's Avatar
Yeah, all four have to be adjusted like markeb01 said. If you have a firm pedal but low, it's likely an adjustment issue.
