Old 04-04-2012, 11:31 AM   #1126
robnolimit
robnolimit's Avatar
Re: Make it handle
Oops, one more, I like the early mustang spring 67-70, it's wide, smooth, and very close to the right sping rate for older p/u's.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 04-04-2012, 03:17 PM   #1127
Lolyin58
Lolyin58's Avatar
Re: Make it handle
Rob very interested in your new front suspension for my 68 GMC. If you could send me a bunch of info and pics that would be great. Its time to change it up as now is the time since I'm doing the LS swap. Can't wait. Talk to u soon!
Lolyin58 is offline   Reply With Quote
Old 04-04-2012, 10:27 PM   #1128
ambryatim
ambryatim's Avatar
Re: Make it handle
Originally Posted by jimmydean View Post
<edit2> Might be a dumb question, but do the bends in a trailing arm matter, or are you looking just at the mount points when drawing your lines? Or does the bend in the back of the arm only for mounting surface? I want to plot out my suspension now and see where it turns up on the scale.
Hello Rob, I was reading thru the thread and never saw where you might have answered this question....so does it matter??
I will be installing the trailing arm suspension on my 57 Chevy Truck and would like to know about the bend in the arms too. As for mounting them do you have to angle them in toward the center of the vehicle like the orginal set is...or can you make them straight.
And attach them to the outside of the frame?? Kinda like this.
http://67-72chevytrucks.com/vboard/s...1&postcount=59
http://67-72chevytrucks.com/vboard/s...4&postcount=52
ambryatim is offline   Reply With Quote
Old 04-05-2012, 11:37 AM   #1129
robnolimit
robnolimit's Avatar
Re: Make it handle
The bends in the factory traling arms were all about packaging. The factory needed a pad for the spring that would be parallel to the chassis, for easy mounting. It was cheaper to bend the arm, than to make a mounting plate with an angle. I'm not so sure about Trailing arms on a 55-59, the chassis is 34" wide, and the arms may contact the frame rail if the truck sits low. Again, packaging comes into play here. Kicking the rails up could help.
Old 04-05-2012, 11:41 AM   #1130
robnolimit
robnolimit's Avatar
Re: Make it handle
Thanks for the interest. Our new C-10 Wide Ride IFS is ready to go. - I've done my best to keep this thread on the tech info, and not sales, so i'll post up all the info in the 'Suspension Marketplace' on a new thread.
Old 04-05-2012, 11:50 AM   #1131
Jonboy
Slots go on anything!
Re: Make it handle
Rob, can you give me a recommendation on a front spring for my truck? I have a '74, static lowered about 6/8. I am swapping in an LS, and will be putting a 1 1/2" sectioned crossmember in. It has a 3" spindle and 1 1/2 coil cut in the front currently. I would like to upgrade the handling somewhat in the future, but still keep the functionality as well. Since I will have the whole front apart, now would be a good time to swap the spring from the 38 year old ones in there now. Any ideas?
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-05-2012, 11:58 AM   #1132
ambryatim
ambryatim's Avatar
Re: Make it handle
Thanks Rob...Did you happen to look at the links I provided in my other post??
The trailing arms they are using are not the conventional type like on the 63-72 year trucks. His are mounted on the outside of the frame. I was wondering if it is better to mount the arms closer together under the truck going to a crossmember or if his method will yield the same results??
I will not be bagging my truck it will be a DD and I might take it out to the Good Guys auto cross at TMS in the near future.
Also what was the factory bend?? 15* (degrees)
Old 04-05-2012, 03:11 PM   #1133
robnolimit
robnolimit's Avatar
Re: Make it handle
We are trying to get Ibach to make some springs, but it's going very slowly. I still like the 3/4t spring with a coil cut. Sounds like a cool truck, The weight difference of the ls swap won't be that noticable.
Old 04-05-2012, 03:15 PM   #1134
robnolimit
robnolimit's Avatar
Re: Make it handle
Yes, I looked at the threads, those really arent trailing arms, as there are upper triangulated links as well. For trailing arms to work, they need to pivit from close to the center of the truck, so that the rear axle can tip, or articulate, without binding. Mini truckers have tried the '2-link' idea, two long bars on the outside of the chassis, mounted solid to the axle, and a pivit forward on the chassis, - and most learned that this is a bad idea.
Old 04-05-2012, 04:14 PM   #1135
ambryatim
ambryatim's Avatar
Re: Make it handle
^^^^Thanks for the info. So how do you think these would work over the oem style arms??
http://67-72chevytrucks.com/vboard/s...d.php?t=387475
Old 04-06-2012, 07:30 PM   #1136
robnolimit
robnolimit's Avatar
Re: Make it handle
Making adjustable arms can be a big help in tuning. Stock non adjustable arms make it difficult to 'square' up the rear axle. With adjusters in the ends of the trailing arms, you can set the rear perfectly square to the centerline of the truck, and hopefully the front axle centerline. - if it's in the right place.
Old 04-06-2012, 07:43 PM   #1137
SCOTI
SCOTI's Avatar
Re: Make it handle
That type of truck arm would definitely be better vs stock. Less structural flex w/more articulation. Porterbuilt makes them w/drop as well @ a similar price vs what other aftermarket vendors sell their 'stock' replacements.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 04-07-2012, 11:34 AM   #1138
robnolimit
robnolimit's Avatar
Re: Make it handle
WOOO HOOO !!!! Wow, 100,000 views!!! Thats friggin cool!!! Thanks guys for keeping the interest up !!!!!!
Old 04-07-2012, 11:35 AM   #1139
67cheby
67cheby
67cheby's Avatar
Re: Make it handle
ummmm...you make it pretty easy for us to stay interested !
67cheby is offline   Reply With Quote
Old 04-07-2012, 12:05 PM   #1140
jayman68
Fun Stuff
jayman68's Avatar
Re: Make it handle
X2, Thanks Rob!
Jay
68 C10(project)
88 Honda Accord(DD)
93 Chevy Astro EXT 2wd
jayman68 is offline   Reply With Quote
Old 04-07-2012, 12:32 PM   #1141
duallyjams
duallyjams's Avatar
Re: Make it handle
It's edge ba cation that even I can understand.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-08-2012, 10:25 PM   #1142
jimmydean
jimmydean's Avatar
Re: Make it handle
Rob, maybe it was covered earlier, but is there a difference in handling between a setup like abadsvt's setup and a standard 4 link? Mine will be like this only using the Corvette IRS. I love the looks, but is there an advantage?
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-09-2012, 01:56 AM   #1143
leftcoast66
leftcoast66's Avatar
Re: Make it handle
Rob, any suggestions on air bags? I don't want to go with ART because of price. I'm leaning towards Slam Specialties RE6 (rear) and RE7 (front) because of the thicker walls versus the Firestone 2500 and 2600 I've been running, any input?
leftcoast66 is offline   Reply With Quote
Old 04-09-2012, 11:01 AM   #1144
jimmydean
jimmydean's Avatar
Re: Make it handle
I had those same bags on my '69 and they were awesome. I would not run any bag but the Slams.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-09-2012, 12:08 PM   #1145
robnolimit
robnolimit's Avatar
Re: Make it handle
Are you talking about the 'Cantalever, or Rocker-arm' for the shockwave? If so, there can be some advantages if done correctly. If you are using an IRS, then a cantilever can help out a lot with clearance issues.
Old 04-09-2012, 12:11 PM   #1146
robnolimit
robnolimit's Avatar
Re: Make it handle
The RE7 is a great bag for the front of C-10. I know everybody uses the 2500 style on the rear, or RE6, but i really like the 9000 style slider bags. They will run at a higher pressure at ride hieght, appx 70 psi, and have a smoother ride.
Old 04-09-2012, 12:27 PM   #1147
jimmydean
jimmydean's Avatar
Re: Make it handle
Yes, the cantilever setup (if that is the proper term). While I should have know Nate had performance in mind, I didn't know what advantage that has. I am aware of the advantages gained with an IRS rear, but the rocker/shockwavr setup.
I am also looking to use the Select Ride series for comfort/performance select on the fly.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-09-2012, 04:43 PM   #1148
leftcoast66
Re: Make it handle
Thanks Rob, I'll go with the 9000 series in the rear then. I'm going to run a triangulated 4 link but from what I've read, the 9000 series are ideal for bag over axle setup. Not a big deal, just wanted to confirm. I'm building the truck to handle, and corner well but maintain the bags on the frame I'm building.
Thanks again,
Brendan
Old 04-10-2012, 11:29 AM   #1149
robnolimit
robnolimit's Avatar
Re: Make it handle
Thanks again,
Brendan
I talked a bit about set-up theory, and that I lean towards a 'soft spring/big bar/low RC' set-up. A typical triangulated 4-bar will set the RC just below the axle CL. the 9000 bags will be fine, I have toy'd with the idea of using 8000 bags, the skinny slider bags, 1100 lbs @ 100 psi, (2 bags = 2200 capacity, more than enough) but never tried it. Good shocks, mounted outboard, and a sway bar will make all the difference for you.
Old 04-10-2012, 12:20 PM   #1150
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Make it handle
Rob, any info on installed dimensions on those f8000s? Can't seem to find them online...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
