Old 04-04-2012, 12:22 AM   #4126
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Project Vitamin C-10
looks great, Alan....can't wait to see it installed!
Thanks Phillip!!
With the help of rbar he pointed me in the direction of these pics.
Alan's Classic is offline   Reply With Quote
Old 04-04-2012, 10:55 PM   #4127
Alan's Classic
Drove it to work today for a 16 mile trip. It did pretty good. The temp gauge was between 3/4 and 7/8 of running hot. I got to work and the used a lazer temp gun and the hottest spot I found was 220 most spots were around 200. The upper rad hose was 190 i think. I'm thinking of cutting some reliefs in the fan shroud so when it's moving down the road more air is able to move thru the rad. I've heard that when an electric fan is on going down the road it actualy inhibits cooling.
It was blowing a little antifreeze out, but not much. It never boiled over.
I got the hood on and tried a little too lined it up. The hinges were really stiff from sand blasting, but with some PB Blaster they freed up a bunch. It's still sticking up in the back and trying to get it down. I don't have a latch in it right now. The latch might help. I'm wondering if the cowl seal is keeping it up. It's spongy in the back. If I push the hood down in the back and let go it comes back up.
I used my GPS and it is reading 10 MPH faster.
Old 04-04-2012, 11:00 PM   #4128
shortbed70
shortbed70's Avatar
Looks and sounds good Alan...
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-04-2012, 11:12 PM   #4129
66ChevyMax
66ChevyMax's Avatar
Coming together nice. Love the sound
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 04-05-2012, 09:47 PM   #4130
Alan's Classic
Thanks guys!!
I spent 2 hours measuring 2 times and drilling once in the right door and fender. Then touched upthe holes and installed the fender trim. Can't install the door trim until I paint the silver.
Installed the hood latch and got it opening and closing. The back of the hood is still up some. I taped down the cowl seal and it helped some.
Old 04-05-2012, 09:47 PM   #4131
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
alan, are you going to have to pull the bed off to paint the silver? gm painted the stripe pretty far in on the back of the cab..
Old 04-05-2012, 09:53 PM   #4132
jonzcustomshop
1961 crewcab
hood looks good, are you going to paint the inside of the vent and the vertical bar satin black like the factory did? IMO that is the best look on a gmc hood..
Old 04-05-2012, 11:16 PM   #4134
Alan's Classic
I'll wrap it as far as I can without removing the bed.
I have never thought of that, but might be an option later on.
Originally Posted by theastronaut View Post
Looks killer Alan!
Thanks man!
Old 04-06-2012, 12:36 PM   #4135
SFTorange
SFTorange's Avatar
Congratulations Alan,
The truck looks amazing!
Sorry if you've already addressed this somewhere in your build thread, but I've found out that you need either a nos or properly calibrated temperature sending unit that matches your older gauges to get them to read correctly. I incorrectly thought that my truck was overheating last summer with the a/c on, but it turns out that the sending unit from Napa doesn't have the correct calibration for older vehicles. As soon as the vehicle gets to operating temperature, the gauge would spike to hot. I'm not sure how this all works with your Impala gauges, but I figured I'd let you know what i learned. I purchased a new sending unit from Lectric Limited and it seems to work great now.
The Brown Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=437222
SFTorange is offline   Reply With Quote
Old 04-06-2012, 02:42 PM   #4136
McMurphy
McMurphy's Avatar
If I am not mistaken, the old guages are 9v and all new systems on 12v?
Getting a voltage regulator to accomodate this is more than I can wrap my head around, which is why I am just going to to with all new guages and set the truck up for 12v all around.
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 04-06-2012, 07:35 PM   #4137
gimmy 64
also on a new motor it is going to run hot because everything is tight. my truck ran about 200 for a good while untill things got broke in. now stays about 190
gimmy 64 is offline   Reply With Quote
Old 04-06-2012, 07:49 PM   #4138
scotts62
One day...
scotts62's Avatar
Dude that thing is sweet, you did a very good job on it!
Scott
93 crew cab build
Project 62
Old 04-06-2012, 09:43 PM   #4139
Alan's Classic
I bought a temp sensor for a 59 Impala. Maybe it was packaged wrong. Thanks for the link.
I might upgrade my guages when i run out of other things to do. I've never heard of the gauges running on 9V. I'm not doubting you just never heard of it.
I agree with that.
Thanks Scott, I appreciate that.
Today I was able to drill the other side and it only took an hour since I had the lay out figured out. So now I'm ready to paint the silver.
Had a little issue with the finish on the mouldings. Discussion link
i snapped the turn signals in, but not wired. Took it outside for a few more shots.
Old 04-06-2012, 10:46 PM   #4140
daverod
SSN 706
daverod's Avatar
The trim is really going to tie everything together. Great job.
daverod is offline   Reply With Quote
Old 04-07-2012, 10:49 AM   #4141
Strodder
Daring to be Different
Strodder's Avatar
Sweeeeet.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-07-2012, 11:53 AM   #4142
C10LIFE
C10LIFE's Avatar
Wow, that really looks great.
At 200 mph you have no friends.
C10LIFE is offline   Reply With Quote
Old 04-07-2012, 01:47 PM   #4143
Old 04-07-2012, 07:57 PM   #4144
flips72
flips72's Avatar
man am i ever jealous, that is nice, when you get the silver and the trim on it i would take a vacation, maybe the rod run in pigeon forge this weekend and drive it with a great big grin on my face. oh yeah if you cant get anyone to go with you stop by and get me i am on the way
flips72 is offline   Reply With Quote
Old 04-09-2012, 12:13 PM   #4145
joesscamaro
Your truck looks awesome! The trim is definitely going to tie it all together and look great!
joesscamaro is offline   Reply With Quote
Old 04-09-2012, 09:44 PM   #4146
Alan's Classic
Originally Posted by Strodder View Post
Sweeeeet.
Thanks guys!!
Thanks, but there's no need of being jealous, you have a truck just as nice. I wish I could make it to Pigeon Forge, but not this time.
Thanks, I think your right.
Got the silver done today. Mar-K also called me and said they hand picked some mouldings and sent them out today.
Old 04-09-2012, 10:12 PM   #4147
likaroc13
Rollin' Old Skool
looks awesome, Alan...i knew that would break up the orange nicely...now when you get those side trim pieces installed, you'll be set!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 04-09-2012, 10:18 PM   #4148
allaboutchevelles
allaboutchevelles's Avatar
Alan, Your truck looks GREAT!! I love the stance of it. I know you probably covered it in your thread somewhere already but what did you do to the suspension to get that stance? I put 4 inch drop springs in the back of mine and ordered 3 inch drop springs for the front.
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline   Reply With Quote
Old 04-09-2012, 10:34 PM   #4149
66ChevyMax
66ChevyMax's Avatar
Totally cool & sweet ride
Craig
Old 04-10-2012, 01:49 AM   #4150
jpbjpbjpbjpb
I just bought a 60 swb stepside and got on this site for some ideas. I just spent the past 4 nites reading every post on your thread. You made an absolutely breathtaking truck. I can't wait to get cutting and building my truck. Thanks for the inspiration.
jpbjpbjpbjpb is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
