"GO DAWGS"
Restored tach gauge rear tin.
I have been trying to go that extra mile in restoring these gauges so I wanted to take it to the next level. Here are two tach gauge rear tins that I have restored with the tin being media blasted inside repainted and the back re stamped with the 8 CYL and the part #6468228 in the factory correct color and the font is spot on to the original. The outside was stamped and cleared to protect the bare metal. The only way I will sell these is if you send me a core in return. I would like $35.00 shipped with your core in return. These are the first two that I have done.
Thanks PT ![]()
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
"GO DAWGS"
Re: Restored tach gauge rear tin.
Here is a pic of a NOS gauge to compare to.
PT
Moderator
![]() Join Date: Jun 2008
Wow! Nice Job
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
![]() Join Date: Feb 2012
That looks amazing. Nice work
You definetly took it to the next level ! Will you share you secrets? What size media did you use? Is that sea foam green?
1971 Chevy shortbox 4x4 made in Canada |
"GO DAWGS"
Yes it is sea foam green and the media is what ever they have in the cabinet at work. I think it is fine grit.
Thanks PT
67-72 parts collector,…
![]() Join Date: Nov 2002
Quality work,... like always!
VA72C10
![]() Join Date: Mar 2008
Nice job PT!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
![]() Join Date: May 2006
Ok, wish i had a core
"GO DAWGS"
Jaros just remove the one from your tach if you have one and send it to me and in return I will send this one out. By the way thanks for the nice comments guys.
PT
#11 | |
Thanks for telling me about Les, just got my sw tin back from him. He stamped it out for my tach, sandblasted and painted it
"GO DAWGS"
No problem anytime.
PT
"GO DAWGS"
Bump
"GO DAWGS"
Ttt
#15 |
Ill be in touch, after i find one......might finally be done with my gauge panel, just have to send out my temp gauge to get it rescreened
Nice work! and ttt for ya
#16 |
Member #1049
Paul,
Have you ever had any issue with a ground stud just spinning while trying to take that nut off the tach tin? |
#17 |
"GO DAWGS"
Never had that problem. Take a little 2n1 oil and put it on the stud and base of the nut and let it sit then try to take two smaller nuts and put them on the stud to hold it then try and back off the nut. Those fat lock may be to big to put two back to back, if so I have some fine tread nuts here.
PT
#18 |
Thanks for the info. Guys
#19 |
Tot Roddin'
That is amazing work PT... simply amazing.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#20 |
"GO DAWGS"
Thanks Nate. Just a little twist to make a restoration more complete.
PT
#21 |
"Junkyard Dog"
![]() Join Date: Jan 2008
NICE detail! Bump for ya.
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
#22 |
"GO DAWGS"
Thanks guys.
PT
#23 |
"GO DAWGS"
Ttt
#24 |
"GO DAWGS"
Ttt
#25 |
"GO DAWGS"
Ttt
