Oh,you can't buy that new
![]() Join Date: Apr 2000
66 questions
I am to look at a 66 tomorrow. isn't that the first year for the NON- stovebolt 6cyl. ? if it is a stovebolt 6 will a typical 70's TH350 still bolt to it? thanx , crossy
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
Senior Enthusiast
Re: 66 questions
Memory tells me the Stovebolt was used until 1962 and the 230 became standard in 1963. Wikipedia states it happened a year earlier. In any event a 1966 wouldn't have the "old" engine unless someone swapped it in.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
60-66 Nut
Re: 66 questions
The 'stovebolt' I6's (216,235,261) were last used in the '62 model year. 1963 was the first year for the 230, and the 292 in the trucks. A '66 would likely have either a 250 or a 292, if it is original.
1961 crewcab
Re: 66 questions
![]() someone transplanted it though.... as mentioned above 63 was the switch to the 230/292, and in 66 the 250 was added to the lineup. the nice thing about these 6's is that a modern chev th350 will bolt right up.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Re: 66 questions
thanx guys- as cheap as the kid is selling it - it has to be a mess but I'll look at it the next few days cuz i'm off. I have to go look at a 70 CST first though. crossy
Re: 66 questions
Dont the 350 trans's only fit directly to the 292's ?
MY ADDICTION STAN THE MAN |
60-66 Nut
Re: 66 questions
No, the TH350 will bolt right up to the 194, 230, 250 and 292 I6's. And so will any other Chevy trans or bellhousing up until about 1999-2000.
Re: 66 questions
Good to know,thanks capt
