04-05-2012, 08:34 AM | #1 |
BOHICA
driveshaft weight
How important is the weight or whatever that is around the u-joint on the tranny end? i have a 3OTT 68 longbed. Changed u-joints, and that piece fell apart in 2 pieces. can I run my truck without it?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig! |
04-05-2012, 05:23 PM | #2 |
I am a Referee of life.
Re: driveshaft weight
Might want to show us a pic.If it's a metal piece that's around the driveshaft,it could be the carrier bearing.If it's a partial curved piece of metal,it could be the weight used to balance the driveshaft.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-06-2012, 09:08 AM | #3 |
BOHICA
I don't have a pic right now, but I'll try to get one this weekend.
It isn't the CB, I just replaced that. I assume it is a weight or vibration damper. It is basically a thick cast ring that fits around the U joint at the tranny end of the shaft. There are 4 half circle cutouts that allow access to the ends of the U joint. It is about 5 inches across and has a rubber ring inside of it. That is the best description I can give right now. Newer trucks do not have them, so I don't know if I need it or not. My truck has a factory overdrive unit as well, so maybe it is specific to that.
