Old 04-06-2012, 04:07 AM   #1
USA69Z
USA69Z's Avatar
front sway bar question..
guys , ive just got myself an ol' 70 stepside to restore,, and wondered did these trucks come with a front sway bar? this one hasnt got one but im thinkin' it needs one? there are no brackets or remnants of any sort under there?
thanx, Gav
USA69Z is offline   Reply With Quote
Old 04-06-2012, 06:16 AM   #2
sameyrasmea72
sameyrasmea72's Avatar
Re: front sway bar question..
It was optional on these trucks. You can usually find one on the parts board.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 04-06-2012, 09:55 AM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
Probably the cheapest way to improve the handling of these trucks.....
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 04-06-2012, 10:29 AM   #4
jhwkns
Registered Cruiser
jhwkns's Avatar
Look for a 1 1/4" bar. Many other year models will interchange. Mines from a '79 C-30. The neoprene bushings last much longer than rubber, but can squeak a little. If you plan on lowering the truck, it's a good idea to relocate the front mounts. Happy hunting.
I just noticed you're from oz. That might make it a little harder to find one in a wrecking yard, but I'd do my best if I were you. Shipping one could be rather pricey. G/L
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 04-06-2012, 11:39 AM   #5
Daddy Bartholomew
I found one last year for $40, and discovered after removing all the decades of dried mud and congealed grease on the front end, all I had to do was bolt it into the existing holes.
Really handles much, much better now. I'm amazed at how much corner sway was eliminated.
Daddy Bartholomew is offline   Reply With Quote
Old 04-06-2012, 12:31 PM   #6
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
http://www.67-72chevytrucks.com/vboa...highlight=sway
Got my 1 1/4" bar from a 73 - 87 Chev or GMC tow truck. Those should be more plentiful than 67 - 72's down there...
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 04-06-2012, 02:48 PM   #7
mtnbikeman
My 1 1/4" bar was from a 79 C-20 from pick and pull for $25. Early classic enterprises has the frame mounts for stock height and lower trucks, they also have bushing and strap kits. I'll probably be in it for about $60
mtnbikeman is offline   Reply With Quote
Old 04-06-2012, 05:02 PM   #8
USA69Z
USA69Z's Avatar
thanx guys ,, there are some around but not in the wrecking yards here.. most guys restore them or stockpile there parts. Ill prob get new from one of the major suppliers and deal with shipping as we do here with everything from the US. at least the aussie dollar is strong right now which helps ..
