Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-16-2011, 09:54 AM   #26
djracer
djracer's Avatar
Re: Just in time for Christmas
Good to see Paul. I just got mine back too but Mine is headed to the paint shop soon. That weight sounds awesome. Have you lightened your doors at all?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-18-2011, 03:48 PM   #27
kpeztruck
kpeztruck's Avatar
I have not lightened my reproduction doors at all. I still have vent windows, and full regulators in both doors, with glass windows as well. I will test 1st weekend in November the way it is, and see if I need to lose more, so I can add in back where I need it to meet minimum weight requirements. Paul
kpeztruck is offline   Reply With Quote
Old 04-06-2012, 01:13 AM   #28
65Pickup
65Pickup's Avatar
Awesome truck, any updates on how your new suspension is proving out? Street and strip, plus what coil over are you running out back? Any tips?
65Pickup is offline   Reply With Quote
Old 04-06-2012, 09:34 AM   #29
hotrod 80
mini truck racer
hotrod 80's Avatar
Nice set up . 2995 is great .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 04-06-2012, 09:44 AM   #30
redsled87
redsled87's Avatar
Are you using the car bolt pattern on your wheels? What size wheel and tire are you running on the back? I also like your color combo too.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 04-06-2012, 03:06 PM   #31
kpeztruck
kpeztruck's Avatar
The suspension has worked out great! Now I just need to motivate the chassis guy to find someone to produce all the brackets for a reasonable cost, so we can produce, and sell them. The rear coil-overs are Koni double adjustables. Tell me what you have in your truck, what it has done on it's passes, and what your goals are, and I will be glad to help you out. Paul
Old 04-06-2012, 03:09 PM   #32
kpeztruck
kpeztruck's Avatar
Thanks redsled, It is a 5x4.75 bolt pattern. The rear wheels are 15x10, with a 29.5x10.5 slick. I will have a new pair of 28x10.5 this weekend to test with in the next couple months. I hope with the converter change, and some tuning time, to greatly improve all my numbers. The colors are Mini Cooper blue, and white for the early models of the modern version. Paul
Old 04-06-2012, 10:07 PM   #33
65Pickup
65Pickup's Avatar
427 DART sbc, 565 hp/tq, 3.73 gears and posi being installed now, and turbo 350- 3500 stall/trans brake. Funding got tight so drag radials are the only traction improvement for the summer. Stock suspension, asking questions and planning for the future. No runs yet. Thanks for any advice.
