04-06-2012, 04:19 PM | #1 |
'83 front suspension onto '65 frame - different bolts?
I'm using the upper and lower control arms, spindles, rotors, calipers and complete steering linkage from a ’83 C10 to swap onto my ’65 C10.
Mine were already removed from the donor truck. Will I be able to use the bolts that hold the ’65 control arms to the front crossmember / frame to bolt on the ’83 control arms? Anyone know if they are different?
____________________________ |
04-06-2012, 07:47 PM | #2 | |
Re: '83 front suspension onto '65 frame - different bolts?
Everything else is the same from what I remember....
04-07-2012, 01:14 AM | #3 |
Thanks.
I'm close to having the drivetrain out.
