Old 04-07-2012, 07:42 PM   #1
Cw72gmc
~Craig~
Will any model q-jet be compatible I have the 4mv now
I am having killer carb issues and cannot get my 4mv to cooperate. I have someone who just had one rebuilt and then went with a different carb. I beleive it is an em4v I know the configuration is about the same other than the carb mounted choke. Is the bolt pattern and base plate the same? will it work?
I have a 72 bone stock 350
Cw72gmc is offline   Reply With Quote
Old 04-07-2012, 09:37 PM   #2
425HP409
425hp409
425HP409's Avatar
Re: Will any model q-jet be compatible I have the 4mv now
What is the carburetor number of the one you want to use?
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 04-07-2012, 10:21 PM   #3
Cw72gmc
~Craig~
Here is a picture, I believe it is an m4me but I cannot be sure.
Old 04-08-2012, 07:45 AM   #4
don t. - 72gmc
What's wrong with it?
FWIW....there should be numbers stamped into the carb. Write em down. The web is your friend to help identify what you really have.
FWIW2...q-jets are real easy to rebuild, kits are avilable. Tons of web sites, including this one, will help.
HTH..good luck...don t. .....
don t. - 72gmc is offline   Reply With Quote
Old 04-08-2012, 09:19 AM   #5
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
That carb will bolt onto any Q-jet intake.And yes, it is an M4ME. The M4M q-jets are great carbs.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 04-08-2012, 09:41 AM   #6
68gmsee
Active Member
68gmsee's Avatar
Keep in mind that carbs are built for specific engines and their specs so you may or may not be getting the maximum efficiency out of the carb. It's worth giving it a try, though.
68gmsee is offline   Reply With Quote
Old 04-08-2012, 10:53 AM   #7
Wrenchbender Ret
That is my favorite carb to work with. The electric chokes work great. You can use it on practically any Q-jet manifold as the choke is self contained. Put a kit in it & seal the plugs in the bottom of the bowls & you will have a carb that works as good as FI.
Wrenchbender Ret is offline   Reply With Quote
Old 04-10-2012, 01:31 AM   #8
profe56
I'd like to see in a picture the plugs in the bottom of the bowls
profe56 is offline   Reply With Quote
