#26 |
Re: cutting rear coils?
looking good!
#27 |
thanks for the advice. its smooth.
#28 | |
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390 ![]() |
#29 |
just an FYI
Just wanted to add a note to this thread about the rear Jeep TJ/LJ springs. There are four different versions of the springs that were used from 1997 through 2006. These are the ones that can be used on the C10. Similar rear springs could be found on the Jeep Grand Cherokee ZJ. All four versions are the same length wise but vary in rate. The only way to tell them apart is by the color coded tags that are on the springs from the factory, they read as follows: 103AA (or 3AA) 130lb. 104AA (or 4AA) 140lb. 105AA (or 5AA) 150lb. 106AA (or 6AA) 160lb. hope this helps
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
#30 |
60-66 Nut
Thanks for sharing the info you discovered.
